Results 1 to 7 of 7
Thread: fuel pump relay explanation
    SE-i Sedan 5 spd
    Maybe someone can explain this to me. I believe I've read here that the fuel pump relay in the main relay box (f.i. engine) operates only when the starter is engaged, and in fact the electrical schematic I have says the 12v source to the relay coil is only "hot on start." If that is the case, how does the fuel pump continue to operate after the engine starts? Obviously I'm missing something fundamental here. Thx.
    Blkblurr's Avatar
    Dayton, Ohio
    Re: fuel pump relay explanation
    The relay comes on when the ignition switch is in position 2
    Its 2 relays (coils i think) in there one needs to see spark from the coil the other energizes the fuel pump. Thats about the easiest way I can explain it.
    There several write ups in the EFI section.
    Jun 2005
    1986 Honda Accord POS tranny
    Edmonton AB
    by spark from the coil, you mean it just needs a tach signal or something right? i mean, isnt it the main relay that energizes the coil?
    Nov 2000
    The fuel pump has power when the key is in the "ON" position. If you turn the key to ON without starting the car you will see and hear the following.
    Check engine light comes on accompanied by a "click" from the relay.
    Check engine light goes off after 1-2 second self test and a second click can be heard.
    When the relay is going bad you will usually fail to hear one or both of the clicks. I believe the first click is the fuel pump getting power and the second click is the fuel pump shutting off after the fuel rail is pressurized. that's why I always wait for the second click (engine light going off) before I start the car. It starts MUCH quicker when the fuel rail is pressurized.
    Quote Originally Posted by newaccorddriver View Post
    I dont think this is going to answer your question but I think the igntion switch powers the main relay, turns the fuel pump on BUT it has about 3 seconds to see the coil signal or it goes off. Remember the relay is there as a safety feature to shut the fuel pump off if the motor is not running. I am not really sure how the 3 seconds is achieved but i have some ideas.
    I do think its the negative side of the coil it reads from and yes that would be considered a tachometer signal.
    Jan 2013
    1981 honda accord
    On 1981 Accord, where is the fuel relay? I have looked thru all books, everywhere. Is it in engine compartment?
    Just point me in the direction.
    1981 Accord with 64,000 orginal miles...driving by little old lady till I got it..hehe.
    Thanks
    Frank
  1. Fuel pump or relay?
    By bongbang in forum 3geez Accords
    Last Post: 10-11-2009, 09:12 AM
  2. How do you remove Fuel Pump Cut-off Relay?
    By nerdmeier in forum Carburetor Tech
    Last Post: 06-01-2009, 11:36 AM
  3. Fuel pump relay ?
    By 79cord in forum 1geez Tech & Performance
    Last Post: 08-21-2007, 05:30 PM
  4. fuel pump or main relay?
    By buish in forum 3geez Accords
    Last Post: 06-25-2006, 04:12 PM
  5. WTB: Fuel Pump Cutoff Relay
    By wildaccordman in forum Trading Post
    Last Post: 09-15-2003, 04:00 AM
