Alright. I'll take first crack.
EACV is in the front of the intake manifold on the top. It's part #8 below:
http://www.hondaautomotiveparts.com/...Y+%28PGM-FI%29
You'll need to drain the coolant to remove it. If your problem is intermittent, I'd doubt it's that. But I'm not sure what it could be. Make sure you're using good gas and that you've had a good tune-up recently. You might also consider changing the fuel filter if you haven't recently.
If you can give more detail, when this happens, how the car runs otherwise, etc. I might be able to figure something else out.
If I were you though, I'd take it somewhere to have it diagnosed. Then I'd log back on here and tell us what you learn.
