Results 1 to 20 of 20
Thread: useing a rear mount to replace your front motor mount
    This Thread Will BE in 2 Posts
    this replaces the front hydrolic mount with a more soild one
    it was pretty easy and only takes about 45mins
    (note i used a old mount from my parts car just to test this i will be getting a brand new mount in a week or 2)
    frist of all you will need this peace from a 8687 accord if yours is aa 8889 the 8889 ones are to thick
    88-89 one to the left 86-87 one to the right
    86-87 one to the left 88-89 one to the right
    88-89 mount
    86-87 mount
    rear mount left hydrolic front mount right
    Re: useing a rear mount to replace your front motor mount
    Frist un bolt the the top nut that bolts the hydrolic mount to the mounting plate thing lol
    then jack up the engine i chose here to jack
    once the mount is removed it should look like this
    now bolt on the 8687 mounting plate
    now the rear mount bolts here
    bolt it on then lower the engine down on to it and put the nut back on tighting it down once your done it should look like this
    i got this idea from AccordB20A and A18A
    Whats the point of this yo?
    its a much stiffer mount and wont break as much as hydraulic ones do
    AZmike's Avatar
    Tucson, Arizona
    It may not be very durable since the front mount supports the weight of the engine, but must tolerate the upward motion as the engine reacts to the force at the wheels. The rear mount was only designed to deal with one direction of force since the weight and torque reaction both go in the same direction at the rear of the engine.
    Mike
    just proves where there is a will there is a way
    I am sure this rig will not surpress vibrations, even so, it should work for a little while esp if you get the dog bone good and tight with some neoprene bushings or what have you, AND the rear mount is in good condition.
    carotman's Avatar
    Montreal South Shore
    Welcome to 2 years ago :d
    https://www.3geez.com/forum/showthread.php?t=52510
    You can't use the USDM bracket if you use the rear mount in the front. The cars that came from the factory with that mount had a different bracket. I have that bracket here and compared it with the old one.
    SEi User ChaseR's Avatar
    2004 Acura TSX, 2019 CRV
    Reno, NV
    I fail to see any permanent benefit..
    Nov 2000
    My observation has been that even though the rear mount doesn't actually "break" it does end up with a permanently altered "squashed down" shape. That's why you pretty much have to replace the rear mount when you replace the front. If you don't you will still have a lot of vibration. These mounts are not the greatest in the world, but they do last about 100-150K miles between changes. So, like ChaseR, I fail to see any long term benefit.
    Cah, this will work ok for a temporary fix. Like everyone else said, this mount was designed for the rear not the front. Instead of wasting your money on a new rear mount, get yourself a new front hydraulic mount.
    Looks Decent, But It would work better if it were filled with Poly.
    Next time we do business If you Cover shipping I'll send you my intact Front Mount
    Idaho
    Brand new mounts fro cheap from me. http://motors.search.ebay.com/_W0QQsassZbitesize1981
    Nov 2000
    That is a good price. I paid over $50 for the one I just got from Majestic. I changed out both of mine last month. It made a HUGE difference.
    carotman's Avatar
    Well, there is no harm in using this mount in the front. The A16A uses that mount anyway.
    good to know !!
    Accord of the Year - 2009
    thegreatdane's Avatar
    Jan 2003
    Denmark/Europe
    Ehh, I fail to see what's hydraulic about your old front mount? You americans keep talking about hydraulic front mounts yet I have never seen proof of any? The ones we have are just plain rubber and look excactly the same as Yours, I havent bothered checking part numbers but I'm betting they are the same.
    Link to my 3geez garage
    the front mount is hydraulic inside,it was a big deal when honda came out with it in the eighties. benifit i see here is using those brackets and making a poly mount to go between them.
    Jan 2003
    Denmark/Europe
    proof? I've never seen pics of one.
    Quote Originally Posted by thegreatdane View Post
    it is it's the big round mount i have the advertisement somewhere, the original front mount if full of oil.
    Reno, NV
    It is indeed full of oil, When I pulled my old motor out it was torn and was full of oil...
  1. Rear motor mount
    By CzEcHy in forum For Sale
    Last Post: 08-02-2010, 12:32 PM
  2. Project new Front motor mount
    By TWOLOUDNPROUD in forum JDM B18A / B20A Swap Tech
    Last Post: 01-27-2008, 07:38 PM
  3. b series: front torque mount + updated mount pics
    By Accordtheory in forum General Engine Swaps
    Last Post: 06-25-2007, 07:55 PM
  4. solid front motor mount
    By race12001 in forum Restoration & Custom Fabrication
    Last Post: 02-06-2007, 03:39 PM
  5. front motor mount
    By franks89sir in forum 3geez Accords
    Last Post: 08-19-2002, 10:10 PM
