Results 1 to 5 of 5
Thread: ground wires
    bridgewater.NS Canada
    Cool ground wires
    hey guys i was looking in my manual and it shows a pic of fuel rail with 2 ground connections on stud.I looked on my and i don't see any on mine.what are they for and where else could they be.also i still can't get my headlight to open.think it might be relay by the rad.
    Re: ground wires
    I'm kinda going off memory here, but the only thing I remember bolting to those is the supports for the AT throttle cable (speed sensor cable?). Where are you seeing the ground wires?
    Can't help w/ the headlight. Sorry.
    Re: ground wires
    it was in the haynes manual,they were talking about removing fuel rail to get injectors out.
    Re: ground wires
    I just checked my Honda manual and there shouldn't be any ground wires connected to your fuel rail. Removing injectors is fairly easy. Again, I'm going from memory here so I might not have all the details right. There are about 4 bolts you'll have to remove. Two bolts hold the injector wire assembly to the fuel rail. The other two bolts hold the fuel rail. Once you've removed those bolts, the fuel rail should pull off of the injectors fairly easily. Make sure you have new seals for all four injectors before you pull the fuel rail.
    I know I said I couldn't help you with your headlights, but it turns out that the Honda manual has several pages of troubleshooting procedures for them. You might take a moment to download the online manual from this site and trying them out.
    Re: ground wires
    Quote Originally Posted by prosenfe View Post
    thanks im not taking the injectors out i was just wondering about the ground wires that they show in the manual.the guy that i got the car from had a lot of things fucked up.
  1. Replacing Ground Wires?
    By Angelois in forum Classic Honda Community Chat
    Last Post: 04-21-2011, 09:39 PM
  2. Ground wires
    By CzEcHy in forum Performance
    Last Post: 02-15-2011, 11:40 PM
  3. Ground wires
    By russiankid in forum 3geez Accords
    Last Post: 08-05-2008, 08:56 PM
  4. ground wires !
    By ACCORD EX in forum 3geez Accords
    Last Post: 01-29-2003, 06:14 AM
  5. Ground wires
    By Jerren in forum Performance
    Last Post: 12-16-2002, 08:05 PM
