Results 1 to 6 of 6
Thread: Oxygen Sensor Wire Coming off of ECU?
    Hey im installing an air/fuel ratio gauge and figured I could get a cleaner signal tying in from the ecu side rather than running the wire into the engine bay and risking interference. Anyone know what color wire this is off of the ecu? I looked in the manual and on here but couldnt find anything. Also what would be the best switched power wire to tie into.
    LX-incredible's Avatar
    Sep 2006
    Tucson, AZ
    Re: Oxygen Sensor Wire Coming off of ECU?
    White. It's the only single wire that gets shielded. All the way at the end of one of the black connectors.
    Best power wire would probably be one of the yellow/blacks, going from the main relay to the white ECU connector.
    CARDONE SUCKS.
    if it's a wideband it won't work right from the factory sensor. you need a wideband o2 sensor i don't think the factory sensor is even normal band
    Its narrowband.
    Thanks.
    sweet....i would replace the o2 sensor tho....my car had one but they took it out when i bought it...they left the connection so i can just plug one back in....good luck...take some pics mr mushroom
  1. Oxygen sensor
    By turabaka in forum Carburetor Tech
    Last Post: 11-08-2007, 09:47 AM
  2. oxygen sensor
    By spades in forum 3geez Accords
    Last Post: 03-29-2007, 03:43 PM
  3. Where to buy Oxygen Sensor?
    By vongiese in forum Classic Honda Community Chat
    Last Post: 02-25-2007, 02:06 PM
  4. 4-wire Oxygen Sensor Conversion
    By carotman in forum 3geez Accords
    Last Post: 02-22-2004, 12:12 PM
  5. Oxygen sensor A?
    By Coroncho80 in forum 3geez Accords
    Last Post: 12-14-2002, 03:26 PM
