I need these parts!
i didn't read the whole thing, but did you go with the POR15? eastwood makes a few products that kick that stuff's butt. just some info, in case you haven't checked it out yet. it seals MUCH better and protects better x 1,000,000.
I did use some POR15 but the project isn't finished yet.
What's the Eastwood product you're talking about?
I need these parts!
Is it possible I could get the source of were you got those rocker panels? I can only find rocker panels for sedans....
'89 LX-i Coupe Auto 308,xxx miles R.I.P.
'88 DX Coupe 5-speed 210,xxx miles and still going
I need these parts!
Keeping it alive, great project... Lucky find on the visors im jealous)
I started to work on the car again.
I gave myself a kick in the butt and decided that I have to work on the car every day. Even if I just remove 1 bolt or grind a square inch of rust, it counts. I'll be able to finish this project by working on this project in little increments. I've been delaying the project for more than a year. If I had done this before, this car would be completed by now...
So far, I almost too out the rocker panel this week. Of course. I'll take pictures when it's completely removed.
I need these parts!
I need these parts!
after you replace the rocker panel spray the inside of it with stuff called honey coat. I used to use that after my 1/4 panel and rocker panel repairs to give the inside some rust protection.
3Geez resident body man
Owner of Wreck-less auto body
Thanks for the input. I was wondering what would be best for long term rust protection. I'll use POR-15 for the paint but weld protection will probably that honey coat
I need these parts!
being your taking your time and doing this the right way, i would put in that extra effort. Por-15 is a great product, many of the guys in the g-body and Oldsmobile community use the stuff religiously. I would also suggest getting a few cans of zinc weld through primer for when you re attach the rocker panel. then use the honey coat to finish it off when your done welding. I also found that using fire proof expanding foam will fill the rocker panel cavity to prevent further corrosion and stiffen's up the chassis a little bit. I did that to my gold hatchback and it made a bit of a difference, not to mention its light weight too.
Hey Carotman - you still out there? Did you ever finish this project?
I have an 88 DX on which I am currently trying to fix rocker panels.
Hi
It isn't finished. I had more important work to do elsewhere I guess. The project isn't dead and I plan to work on it soon.
I need these parts!
Come on carotman! If it was not for your website back in 2002 I would of never known that accords could of been modded.
