Results 1 to 6 of 6
Thread: Power Issue
    Feb 2008
    1987 Honda Accord LXi
    Los Angeles, California
    Power Issue
    So during the weekend I installed an Amp and Subwoofer. 1x 700W amp 2x 10" Sub's 700W. Powering one sub is hard on the car, I can just tell the alt is being stressed to generate enough power which is bad.
    So... basically my problem is not getting enough power to them.
    What should I do?
    Should I get a new car battery or should I go to the junk yard, buy a battery there and use that battery to power the amplifier itself. Is that possible or? I don't know what's that called so I don't know how to search for it.
    Currently I have a Valucraft, delivers 525 CCA/650 Cranking Amps, I bought it 3 months ago.
    What are some decent batteries? an Optima is nice but I can't afford that anytime soon. I'm looking around $100 to spend but if there's a way to make a car battery act like a capacitor I'm there. Any drawbacks to such a system?
    Any info helps, thanks guys!
    Re: Power Issue
    Quote Originally Posted by zAFW View Post
    What should I do?
    i was running 2700 watts on my stock charging system with no prob sounds like you have eather a bad alt a bad batt or a crappy amp
    or it could be the wiring lol
    i was runnign a batt i got a wallmart for like 60 bucks that was 800cca and 110 crank amps and 2.5 fared caps
    the caps help alot but arent there to support the charging system
    DX User jenkinsauto's Avatar
    Aug 2007
    1986 HONDA ACCORD DX HATCH/1978 FORD F100/1996 FORD ESCORT WAGON/1994 PLYMOUTH VOYAGER
    OHIO
    Talking Re: Power Issue
    First Thing I Would Do Is Upgrade Your Charge Back Wire From Your Alt..the Honda Has A Small Wire That Charges Your Battery,i Used A 4 Gage Wire And Ran It From The Alt To The Battery.so The Power Is Always There.helped A Bunch And Now My Headlights Don't Go Dim When The Bass Hits..try It Cost About $10.00.
    Feb 2008
    Re: Power Issue
    I would hate it being a bad alt, it's hard taking that crap out. Anyway I'm going to check the wiring, could be something on my part which probably is hah. If not I'll stop by kragen or something and have the alt/bat checked out.
    But man! Actually, running that amp off a car battery itself is a good idea. To charge the battery I could use one of those solar panel things I saw Kragen sell. Though the only thing I would need to know about is how to stop it from overcharging and stuff. It's a peace of mind to me since I won't have to worry about the system you know?
    Anyhow just some thoughts.
    jenkinsauto:
    I'll have to take a look and see where that wire is, sounds like a good idea!
    Feb 2008
    Re: Power Issue
    I fixed it.
    Turns out that the red wire I used was the culprit. It wasn't connected to the battery very well. I don't know what I was thinking. Now I got both the 2 10" subs workin' with no problem.
    Thanks guys! I would have thought buying a new battery would have solved the problem.
    Re: Power Issue
    I fixed it.
    you might still want to look into a like a 1 ferid cap they help with the bass alot
  1. Power Steering Issue Returns
    By DBMaster in forum 3geez Accords
    Last Post: 02-17-2011, 05:28 PM
  2. 82 Accord Hatchback Stall/ Power issue
    By nickziemann in forum 2geez Accords
    Last Post: 01-08-2009, 10:45 AM
  3. Replies: 19
    Last Post: 01-15-2007, 04:12 PM
  4. Replies: 2
    Last Post: 02-02-2004, 08:59 AM
  5. Another power window issue
    By Sabz5150 in forum 3geez Accords
    Last Post: 07-09-2003, 09:15 AM
