Results 1 to 5 of 5
Thread: bigger cam
    LX User evil88accordLX's Avatar
    Jul 2007
    gold 88 accord lx
    NWA (not the rap group)
    bigger cam
    i will (hopefully) be picking up a cylinder head to rebuild from the jy this weekend, with plans to port the exhaust side. a weber, header, test pipe, and exhaust are also on the bill in the near future. if i need to replace the springs, valves, and rockers so be it. i would also like to pick up a longer duration cam (272 i believe). is there a cam from any other hondas that i can use that is a direct swap, and if so what year and models should i look into? id rather keep it honda than aftermarket if possible.
    and also, would a mild porting of the intake side really make much of a difference on a carb'd vehicle?
    Re: bigger cam
    Quote Originally Posted by evil88accordLX View Post
    i dont think there is cause if there was you would have heard about it by now lol
    Re: bigger cam
    delta has cheap regrinds....i think they go for like 100 bucks. the 272 is a good starting cam.
    if you need a port and polish head i have one.
    Re: bigger cam
    Of course any porting and polishing will help regardless of fuel delivery system.
    The Delta 272 is a Honda cam, they are oem cams reground.. that is why you have to send them your cam to get one.
    89T's Avatar
    Apr 2004
    Re: bigger cam
    was the head flow benched?
    do you have the flow bench data?
    shoot me a pm on price.
    un-motivated!
    3GR
  1. bigger injectors
    By 88lxi-shortram in forum Performance
    Last Post: 11-10-2010, 09:07 AM
  2. Bigger engine??
    By sk8ordie133 in forum General Engine Swaps
    Last Post: 05-17-2006, 06:14 PM
  3. Bigger engine??
    By sk8ordie133 in forum Performance
    Last Post: 05-17-2006, 08:46 AM
  4. bigger injectors?
    By b8er in forum Performance
    Last Post: 10-19-2005, 12:39 PM
  5. bigger injectors?
    By pervasto in forum Performance
    Last Post: 08-03-2004, 09:27 PM
