It seems like a lot of people (including me) are experiencing distributor issues (typified by the jumping tach needle). Napa wants nearly $600 for a rebuilt, so I bought a scrapper from the wrecking yard and tore into it tonight. I was going to do a rebuild how-to but here's what I found:
- The vacuum advance is bad (~$75 from Napa)
- The advance mechanism bearings are bad (not available)
- All the seals are bad (some available from Majestic)
- The main bearing is bad (not available)
- The crank angle sensor tests okay, but is oil saturated from the bad seals (not available)
- I don't know how to test the igniter (ICM) but would like to replace it (~$105 from Napa)
Anyway, I don't hold out much hope for overhauling these at home and saving any money. Majestic sells the assembly new for about the same as Napa, so I'm probably going that route.
If anyone has any ideas, I'm open.
