Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
Thread: Yet another thread about my flickering lights
    LX User PDXAccord79's Avatar
    Aug 2010
    79 Accord 1.8L CVCC 5-Speed
    Portland, OR
    Re: Yet another thread about my flickering lights
    I've found one here and it looks like it will work. How do you wire it up to the car?
    You gotta jump some wires near the external regulator but I don't even remember which one is which since I already had my engine harness remade and removed the unused wires from the stock setup but if its anything like mine with 2 pins (3 total including main battery/charging post):
    Pin #1 - S or sense. This senses the actual battery voltage to maintain 14.5v output. Connect to your positive terminal on the battery. You could jump this to the bat post on the alternator but its not recommended as this pin senses the actual battery voltage to maintain 14.5v output. Since old wires tend to corrode and have extra resistance you might get say 0.5v voltage drop at the battery. It senses 14.5v at the output post while the battery would actually get 14.0v
    Pin #2 - L or light. This would go to the charging lamp/bulb on the dash which I believe to be the white with blue stripe wire near the regulator. But then I could be wrong fml I gotta recheck
    Do let me know how many pins your alternator have, I could help with the wiring.
    Aug 2010
    Portland, OR
    That's how many the one I'm looking at has: 1 for the main wire then 2 smaller terminals that look like they can take spade connectors. I think your instructions should work fine but I'll let you know if I run into issues. Thank you.
    Aug 2010
    Portland, OR
    This is what I'm thinking of buying:
    More Information for REMY 14301
    Hmm that looks just like the stock one... is there a regulator built into that?
    Aug 2010
    Portland, OR
    Looks like it. The post is labeled BAT and the plug only takes 2 wires. There's like 4 going into ours.
    EDIT: I was wrong, that's a generator. There's a Beck Arnley that's internally regulated for like 10 bucks more.
    Aug 2010
    Portland, OR
    Ok so I have the alternator and know what wires are what on the back. However I'd like to know if you ran the sense wire from the battery back to the alternator or if you just piggybacked it off the BAT post. I'm hoping this finally fixes my turn signal/headlight flicker issue.
  8. #33
    Its better to run it all the way to the battery. I believe I've explained why in my old posts I don't remember
  1. Oil Light Flickering
    By Lil Mike in forum 2geez Accords
    Last Post: 11-29-2007, 06:28 PM
  2. Alternator light flickering
    By visionguru in forum 3geez Accords
    Last Post: 11-11-2006, 08:58 PM
  3. Guys... flickering oil light? WTF!!
    By AccordEpicenter in forum Performance
    Last Post: 05-09-2006, 05:28 PM
  4. Flickering lights
    By Hazwan in forum 1geez Tech & Performance
    Last Post: 05-09-2006, 10:53 AM
  5. Question about lights Dimming/flickering
    By RobT5580 in forum 3geez Accords
    Last Post: 01-14-2003, 11:29 AM
