Results 1 to 15 of 15
Thread: Front sway bar, yes or no?
    LXi User Catalyst's Avatar
    Dec 2006
    87 Accord Lxi Hatchback
    Murphys, CA
    Well I'm going to be ordering my ST sway bars here pretty quick, and I wan't some opinions on what I should get. Originally, I just planned on getting the set, the front and the rear. But I have heard some people say that a bigger front sway bar is less beneficial as it causes oversteer? Is this correct, what do you guys think? Should I just stick with the rear, or get both? The car is an LXi hatch, so it already has stock bars.
    What are your opinions on this?
    Re: Front sway bar, yes or no?
    Well From What I've heard The Front End Will Feel TOTALLY Different with the ST Front, and yeah it might oversteer a bit
    I'd Stick with a Rear for now unless you save ALOT in shipping for both
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    Well technically speaking... the vehicle would tend to oversteer more with a stiffer rear end and softer front. So, just adding the rear will tend to push the car to oversteer a bit more.... Having both, I can't say for sure what it will do, I have heard it makes the steering feel more stiff, and the vehicle may still tend to lean towards oversteer a bit more...
    I have the set, and should be installing it this weekend if all goes well with my inspection on friday.
    Dec 2006
    Murphys, CA
    Thanks for the info guys.
    Forrest, the place I was looking to buy from has free shipping no matter what I decide to go with, so thats no biggie.
    Hash man, let me know how the car feels after you get yours installed.
    Any more input would be much appreciated!
    man i need to get off my ass and install mine lol and our cars have natural under steer so stiffening the suspension will even out the car. if you make it too stiff it might over steer i suppose but i dunno if sway bars alone will do it
    Calgary, AB, Canada
    Will do. I am planning to throw on the tokico/h&r setup along with the sways if I pass inspection.
    Well I was talking to Carotman today and he has ST's and his oversteers he says
    LX User rustlude87's Avatar
    1987 Honda Prelude Si
    Always put front and back on. When I put my front koni on the lude it was much better it the turns, and a lot more grip.
    Vanilla Sky's Avatar
    1999 Penalty Box
    If you have the money, get both. Personally, I'd get just the rear and save the cash. The front can always be ordered down the road.
    i installed my front ST bar and i love it....i didnt install my rear one because i ordered a 4th gen bar....get both...they are both tuned to the car.
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    the car is built with UNDERsteer. A stiffer rear bar will cause OVERsteer so it will balance out. If you order a front ST bar for our cars, and a fat-as-fuck rear 4g bar, id say your car would be over-all pretty well balanced.
    Personally, i have front and rear ST bars, made the car feel amazing! Really seemed to stiffen up the steering, i dont really feel any understeer at all any more
    '89 SE-i Coupe
    Awaiting Garage
    Dec 2006
    Murphys, CA
    Awesome, thanks for the input guys. Looks like I will be getting both the front and rear.
    I've also been reading up on the addco sway bars, which seem to be a better option that ST bars. If I can locate those instead, should I but them? I would assume that the addco bars being thicker would be better.... but it seems they are rather rare nowadays.
    Calgary, AB, Canada
    Ya I'm pretty sure the addco were discontinued a while back, but from my understanding, if you don't plan on running rear discs, the rear addco bar is the way to go... the ST bar is still bigger in the front i believe
    2drSE-i's Avatar
    Oklahoma City
    the ST front bar is the same size as the addco front, but the addco rear is larger, but doesnt work with rear discs. If you want a larger rear sway bar with rear discs, go with 4g rear.
    '89 SE-i Coupe
    Awaiting Garage
    ericw managed to run rear disks with the addco rear...look up his thread on that.
  1. ST front, addco rear sway bar?
    By Accordtheory in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-26-2010, 09:21 AM
  2. Front sway bar.
    By Rendon LX-i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-12-2009, 07:59 AM
  3. Front Sway Bar Bushings
    By stolenracer in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-06-2004, 10:29 AM
  4. Front Sway Bars
    Last Post: 05-21-2004, 11:18 AM
  5. FS:Front and Rear '89 LXi Sway Bars
    By 88LXi68 in forum Trading Post
    Last Post: 03-23-2004, 06:50 PM
