Results 1 to 7 of 7
Thread: The mod has a question
    Sabz5150's Avatar
    1989 Accord SE-i coupe
    Richmond, VA
    Alright, I'm the one needing the knowledge here, and I hope my fellow SE-i owners can assist in that.
    What can I do with the harness that originally went to the Bose amp? Is there a pinout somewhere perchance, and best of all... can I get rid of it? Snip it, heatshrink the wire ends and bundle it back up.
    If there's a constant 12, and ignition 12, that would be reeeeeeeeal nice.
    glorious!
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    Re: The mod has a question
    I would be interested in finding out about this as well. I've spent hours staring at it, and it pisses me off.
    My dad at one point tried to remove it, and hes convinced that its tied into the 3rd brake light as well....
    '89 SE-i Coupe
    Awaiting Garage
    race12001's Avatar
    Sanford NC
    just take a test light and see its that easy
    Dec. 05-Dec. 06
    Sabz5150's Avatar
    Richmond, VA
    Well, chopped the plug and section of harness and cleaned it up... nothing was lost.
    glorious!
    I could look on the wire diagrams for other cars made around the same year, something that would more commonly have the bose system. Did Acura or Sterling use that Bose set up?
    SE-i Sedan 5 spd
    I have a copy of the Bose Schematic. 12v is hot to the amp in accessories or run position, delivered in the yellow/red wire. The white/green wire to the amp is labeled as "switched B+," whatever that means.
    Jan 2008
    89 lxi
    Bethlehem
    Not sure if this is what your looking for but here you go anyway.
    AMPLIFIER OUTPUTS
    Wire Function Color Note Fuse # Size Location
    12V DC Battery Yellow/red 13 10 amp Relay box in right side of engine compartment
    Left Front Mid + Blue/green
    Left Front Mid - Gray/black
    Right Front Mid + Red/green
    Right Front Mid - Brown/black
    Left Rear Mid + Blue/yellow
    Left Rear Mid - Gray/white
    Right Rear Mid + Red/yellow
    Right Rear Mid - Brown/white
    RADIO HARNESS
    +12V DC Battery(Constant) Yellow/red 13 10 amp Relay box in right side of engine compartment
    Switched Accessory White/yellow 11 10 amp Relay box in right side of engine compartment
    Ground Black
    Power Antenna Yellow/red
    Remote Turn On(output) NCA Possibly white/green
    Illumination Red/black
    Left Front + NCA Green, yellow, red, blue & white go to the amplifier.
  1. Idle Question / CAI Question
    By MECM in forum Classic Honda Community Chat
    Last Post: 05-16-2007, 10:50 AM
  2. Replies: 4
    Last Post: 08-09-2005, 12:09 PM
  3. Question about 88 Accord and engine swap question
    Last Post: 03-05-2005, 10:49 AM
  4. carb question?/ auto tranny question?
    By accordlxi2.0 in forum Carburetor Tech
    Last Post: 09-25-2004, 03:01 PM
