Page 12 of 38 FirstFirst ... 2891011121314151622 ... LastLast
Results 276 to 300 of 936
Thread: Vector - 1988 DX - RWD Accord
  1. #276
    Re: Project X: RWD Accord
    what are you gonna do for a hand brake?
  2. #277
    i know what he could do if they still make it, they used to make a system where you could turn a key,then press the brake pedal locking the brakes. a lot of delivery drivers used to use them.
  3. #278
    SEi User 86ccord's Avatar
    Middle Georgia USA
    wow man, good work, im rdy to see this thing completed!!
    one day I'll return.
  4. #279
    LXi User Vector's Avatar
    88 Accord DX-RWD
    Kelowna BC
    couldn't imagine that being good for the rotors overtime. i will think of something.
  5. #280
    May 2008
    "The Phoenix" '88 DX Hatch A20A1 5-Speed
    Santa Clara, CA
    so with the drivetrain being switched to the rear are you going to be getting a new kind of suspension instead of the indepandant rear, cause if you pump too much power into that car it wont go around corners any better than the front wheel drive. maybe even get a limited-slip diff. but just wondering
  6. #281
    Quote Originally Posted by chowder View Post
    what about a legend read end?
  7. #282
    88 Accord DX-RWD
    Kelowna BC
    why would be be any diferent than any other car that has rear independent suspension? all i have to do is make sure my weight distribution is near 50/50 as possible and then find my best spring rates and shock adjustments and i should be good to go. as far as making it non independent or changing the suspension wont be possible being its mid engine, and i will most likely need to stay with the setup that came with the chassis.
  8. #283
    are you using a front suspension on the rear? if so are you going to use fixed links to hold the spindles in place? if not how are you getting power to the rear wheels. another option people might have on this type of setup, is to turn the motor sideways, put the tranny in the back then run a torque tube down the center. you could also use my idea of the small odyssey battery in a box behind one of the seats. this reduces your battery weight to around 15 pounds, and moves it to the middle of the car.
  9. #284
    88 Accord DX-RWD
    Kelowna BC
    suspension is as it was in the cb7 front end... battery will reside in the front passenger side under the hood. page 3 or something shows what i used from the cb7.
    i made a cable -> hydro converter for the car that only uses a small portion of the cable from the pedal... tomorow i will mount it up and get pictures.
  10. #285
    2.0Si User cubert's Avatar
    Feb 2003
    2012 Civic si, old bikes.
    NH
    you sir, are mildly insane...
    this whole thing is absolutely badass....
  11. #286
    88 Accord DX-RWD
    Kelowna BC
    i'm sure i'm passed that point now!...
    think i could hit 14's 1/4m if the motors in good shape and nothing breaks?
  12. #287
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    Quote Originally Posted by Vector View Post
    i wanna see some vids of that thing launching like a mother!!! i wanna see that front end up!!!
    -Gio
    My E85 Turbo Build
    5280FEST
  13. #288
    bu bu bump it up
  14. #289
    It works the same with our rear disc setup's from SE-i's. So here, instead of a cable pushing the pads against the rotor, you are just using the brake lines(line lock).
    Anyways, looking forward to seeing this thing completed!
  15. #290
    whats the status on this
  16. #291
    i wanna se a vid of this beast
  17. #292
    88 Accord DX-RWD
    Kelowna BC
    still alive.... i ran out of money for a while hahahahha....
    i have bought
    yonaka lightweight racing seats
    new cv axles
    clutch
    clutch line and fittings
    clutch slave cyl
    i've just been busy with family stuff also.. i would like to get the rest of the welding under the car finished tomorrow. get the clutch in and axles. if i can maybe even start installing the fuel system.
    weather here has either been to hot or just shit to work in. and because i'm working outside i have to go by that.
  18. #293
    good shit just wanted to make sure everything was ok lol
  19. #294
    oh cool a update, no new pics but you're excused (for now) :P :P :P :P:
  20. #295
    Im sure it will be worth it whern its done
  21. #296
    88 Accord DX-RWD
    Kelowna BC
    haha besides ya guys here, i have quiet a few people here to that are expecting this thing to run, so its not like i can stop now. i even have a few a guys @ the local honda dealership here wanting to see it. i will take it to them to have the oil changed in the engine since i havent done so yet. had to explain to them why i was installing parts from a 4/5g lude into a 3g accord .
    i will try to get some pics today of the pile of parts i've accumulated.
    had some wicked thunder showers last night and its nice an cool out today.. so i will probably get quite abit done as long as i dun get wet.
    ps.i haven't really looked at it, but is it pretty easy to setup a 3g garage?.
  22. #297
    carotman's Avatar
    Montreal South Shore
    For the Handbrake, you can use this:
    http://www.sportcompactonly.com/K-Sp...37_p-90208.htm
    I need these parts!
  23. #298
    84Accord's Avatar
    Jun 2008
    1984 Accord LX
    i saw on another site that someone used a motorcycle rotor and caliper on the driveshaft. maybe you could find something similar to use as an ebrake
  24. #299
    Quote Originally Posted by 84Accord View Post
    We have two axles, so that wouldn't really work, unless he used two brake calipers.
  25. #300
    i have bought
    new cv axles
    clutch
    clutch slave cyl
    sounds like you could be living next door, same here...on most all counts
    think it will tote the front tires a little.?.. that wll be killer
  1. My 1988 accord LX
    By honda crew in forum Classic Honda Pics & Videos
    Last Post: 01-28-2012, 12:24 AM
  2. Vector - 1986 LX - ITR Accord
    By Vector in forum Performance
    Last Post: 06-29-2010, 12:36 PM
  3. Vector - 1988 DX - RWD Accord
    By Vector in forum Project Central
    Last Post: 12-07-2009, 10:32 PM
  4. Replies: 8
    Last Post: 10-20-2007, 04:25 PM
  5. My 1988 Accord LXI
    By ZiggyxFresh in forum Classic Honda Pics & Videos
    Last Post: 08-24-2004, 07:25 PM
Tags for this Thread
