So I have searched without much luck. I keep reading that the idle should be 750rpm with all accessories off? Is that true? If so, then when I turn my lights on, the idle goes down. Right now, my idle stays between 950-1000rpms, and goes down to 750rpm's with lights on, and doesn't change if the defroster is turned on.
If I set my idle at 750rpm, and say I turn my lights on, wouldn't that cause the idle to go down even further?
