here ,some of the pics on my thread still work, dam image station. https://www.3geez.com/forum/index.php
The site just took me to the 3geez main page.
I just took a big pry bar and checked my lower ball joints. They didn't budge one bit, so check yours before you attempt this.
here,sorry about that https://www.3geez.com/forum/showthrea...pindle+rebuild
ok, just got off the phone w/ Summit.
ARP Studs:
Standard Length:
P/N: 100 7709 $17.95 Per set of 4 studs
Extended Length:
P/N: 100 7711 $17.95 Per set of 4 studs
Moog - Front Lower BallJoint:
P/N: K9385 $43.99 each
Moog - Lower Front Control Arm Bushing Set
P/N: K9759 $33.39 each
That's all I got...
-Mark D.
you should be happy,those are really good quality parts. the lug studs are so much better then stock. never understood why honda built such a nice car,but put such weak studs on it. when you put the boot back on the ball joint, it's an expanding ring, you'll have to spread it out with something,then lock it in that position,maby a small pair of needle nose vise grips, then slip it over the joint expanded and release the visegrips. you'll see what i mean when you get it, the ball joints cannot go through with the boots on.
