Results 1 to 25 of 34
Thread: Balljoints
    LX User bank2me's Avatar
    Apr 2008
    88 Accord LX-i
    Portage, WI
    Balljoints
    So how do you guys tell if the balljoints are bad?How can you tell when they are on the car?
    Re: Balljoints
    Jack the car up, and wiggle the wheel side to side, back and forth. The wheel should not move and be sturdy. For the rear, jack up that car, and grab a hold to the spindle assembly and wiggle it. You should not get any movement.
    If movement is seen, further inspection is needed to track down which one it is. Also, when the ball joints go out, they like to squeak.
    Apr 2008
    88 Accord LX-i
    Portage, WI
    Re: Balljoints
    I thought if movement is seen going back and forth that means a bad tie rod?
    Re: Balljoints
    Quote Originally Posted by bank2me View Post
    Well the tie rod is a ball joint...
    Re: Balljoints
    jack the front of your car up and prise the wheel up and down with a crowbar to check bottom balljoint play.
    Re: Balljoints
    i replaced mine after they looked dry and riped...all brand new front ball joints.
    DX User fullthrottle_man's Avatar
    Jan 2008
    1981 Honda Prelude
    Great Falls, MT
    Re: Balljoints
    Not always. My 1g Prelude had a bad ball joint and it only wiggled side-to-side like a tie rod does. It was tight trying to move it up and down.
    Also, another symptom of a bad ball joint is clunking when hitting bumps...
    Apr 2008
    88 Accord LX-i
    Portage, WI
    Re: Balljoints
    My bro had to change his balljoint recently on his 91 maxima and it was like a creaking sound. When I pushed down on the front it would squeak. When I drove it it almost sounded like something was about ready to snap (creaking noise). My honda sometimes makes a clunk noise when I hit a pothole, like something is loose in the front. I will prolly just pry between the balljoint and see if it moves.
    Re: Balljoints
    i replaced my hub
    Apr 2008
    88 Accord LX-i
    Portage, WI
    Re: Balljoints
    A18 How did you know it was bad?
    Re: Balljoints
    the person who i got the car from said it needed one. i wouldnt of known otherwise, lol
    DX User Layson's Avatar
    Apr 2008
    Corvallis, OR
    Re: Balljoints
    There shouldn't be any movement. I just replaced the ball joints, wheel bearings, tie rod ends, and lower control arm bushings. All not too hard to install if you have a press.
    The ball joints and tie rod ends are real easy to fix yourself. You don't need any special pullers or tools to replace them. They are pretty cheap to replace!
    87 Hatchback Lxi - 294,000 miles - 5 Speed
    Apr 2008
    88 Accord LX-i
    Portage, WI
    Re: Balljoints
    How would you not need any special tools to replace the tie rod ends and balljoints? I would think atleast a puller?
    LX User fogged's Avatar
    Jul 2007
    89 LXi Coupe 5spd
    Olathe Ks.
    Re: Balljoints
    Lower balls press in and out. I had to use a puller to get mine off. On a side note the upper ball on the LX-i is premounted on the control arm. My ? is can you use the upper control arm (with a replacealbe ball joint) from the LX, so it would be cheaper in the next time it has to be done.
    Apr 2008
    88 Accord LX-i
    Portage, WI
    Re: Balljoints
    Good question. So for doing lower you would definately want a puller. ok
    a pile of lawn ornaments
    Newtown, CT
    Re: Balljoints
    Quote Originally Posted by fogged View Post
    All control arms and ball joints are the same throughout all trim levels and body types, so there's no cost savings of going one over the other. The upper control arms are purchased as a whole unit which includes the ball-joint, so there's no need to worry about pressing any or in/out.
    Honestly, if you're in doubt, or unsure if they are still good, just replace them, especially the lower front, and upper front and rear control arms. I had a rear upper let go on me while driving (and did not notice ANY strange sounds, or very sloppy handling [any moreso than what would be expected with bone-stock susp.]) and it's definitly not fun, and one tow to your house will cost you more then a complete set of ball-joints and control arms if you DIY.
    Replacing them is money in the bank if you ask me.
    -Mark D.
    Re: Balljoints
    https://www.3geez.com/forum/showthread.php?t=64456
    I found these here. Good deal and the joints replaceable. So far they are working well.
    Re: Balljoints
    I haven't been enormously impressed with the whole tire wiggling procedure. There are just too many variables when you are that far from the jt in question. If you do get play, it could be a bad ball jt or a tie rod. It could also be a bad wheel bearing, any of 35 bushings, a bad rack and pinion, bad strut, loose lug nut or just tire flex. If I am in doubt, I grab the suspension members near the jt and yank them around, feeling for play.
    In truth though, I watch rubber. If your boots are cracked and the grease is gone, the jt is bad presently or will be before too much longer. If you have cracked boots, you have jts that need love. I can't seem to find boots for less than jts, so I usually just change the jts.
    Re: Balljoints
    in reckon. if theres no grease its going to fail someday, and knowing luck it will be when your cornering at high speed.....
    Apr 2008
    88 Accord LX-i
    Portage, WI
    Re: Balljoints
    Yea I've had one replaced and the fuckin guy made it sound like it was some big job. So how long does it actually take and what type of tools do I need? I've never done them so might take longer.
    Re: Balljoints
    The uppers are reasonably easy. You should rent a front-end kit from Kragen. Also use a torque wrench to get all the bolts torqued right. Also check my response here regarding squeaking:
    https://www.3geez.com/forum/showthread.php?t=64943
    If memory serves, the lowers are a pretty big job as you have to pull the knuckle and take it to a shop to have the new ball joints pressed in. Getting them in is tricky, so don't let idiots do it.
    If you're going to go to all the trouble, you might consider replacing wheel bearings, CV boots and whatever else might need it while it's all apart.
    Good luck!
    Apr 2008
    88 Accord LX-i
    Portage, WI
    Re: Balljoints
    Can I press the bottoms in myself?
    Newtown, CT
    Re: Balljoints
    some claim that you can, and some (me included) say leave it to a shop w/ a press, and have them do it.
    -Mark D.
    Re: Balljoints
    If you have a big enough vice you can do it yourself. All you would need is some type of thick pipe to go on the side of the joint where it goes through the control arm so you do not damage it. You will need a cheater bar. I have never done this on a 3gen Accord, but I have seen people do it this way.
    Re: Balljoints
    you can knock the old ones out with a big hammer,after you take the spindle off the car. there is a circlip on some of them,some of the replacment ones don't have a circlip. doesn't matter if you damage the old one,it's junk anyway. i used the moog, get them from summit,best deal you'll get on a quality balljoint. moog says you can leave the boot on during assembly, but theres no way to put it through the hole in the wishbone,unless you remove the boot first. you can reinstall it with a big socket and a vise, vise goes on the flat side of the ball joint,and the socket goes over the end that sticks through the hole{the threaded part}. while you have the spindle off,go ahead and have the wheel bearings replaced,they are not that expensive. i would not drive a car this old with original wheel bearings. try to get the nsk bearings if possible. cheap insurance. also while they are doing the bearings,have new wheel studs put in, you can replace all eight in under ten minutes with the hub off. wheel studs get metal fatique over time, they may look fine,but they have seen a lot of stress in their life. i bought arp ones from summit. not too bad in price,actually cheaper then chinese made ones at autozone. the arp are much much stronger then original, and they are designed to start the lug nut without crossthreading. good insurance against the idiot at the tire store also. very hard to snap off.
  1. bushings and balljoints??
    By King Peetis in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-17-2009, 12:02 AM
  2. Godamn Balljoints!
    By FyreDaug in forum 3geez Accords
    Last Post: 06-14-2005, 11:45 AM
  3. balljoints
    By lightbulblxi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-30-2004, 09:15 PM
  4. new upper balljoints r in!
    By Mantis88LX in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-26-2003, 09:39 AM
  5. new balljoints, do i need alighnment
    Last Post: 01-21-2003, 08:33 PM
