Results 1 to 7 of 7
Thread: Metallic clank when cornering
    nfs480's Avatar
    1989 Honda Accord SE-i
    Rogers, MN, USA
    Exclamation Metallic clank when cornering
    Sometimes, but not always, when i'm turning a sort of hollow metallic clank can be heard from the front left side suspension. It almost sounds like what it would to tap a empty metal trash can with a metal pole. It usually only happens when turning but occasionally it will occur at other times. It doesn't seem to have any relation to major bumps or roughness in the road, so I don't think it is shocks. Anyone have any suggestions or ideas for what I could look for if I jack up the car? Thanks.
    2.0Si User cubert's Avatar
    Feb 2003
    2012 Civic si, old bikes.
    NH
    Re: Metallic clank when cornering
    cv joints?
    nfs480's Avatar
    Rogers, MN, USA
    cv joints?
    That's kind of my #1 guess right now, but I don't know how to confirm that. How do I inspect the CV joints?
    Ichiban's Avatar
    North of You.
    I had a trashed swaybar endlink bushing that made that exact noise. New bushing=no noise.
    ICHIBAN!
    "Now, even more better!"
    nfs480's Avatar
    Rogers, MN, USA
    Quote Originally Posted by guyhatesmycar View Post
    Thanks, i'll make sure to look into that.
    I agree that it's probably a bushing. CVs usually make a clackity, clackity noise as you go around corners. If you want to check them, turn the wheels to lock and go around in a circle listening for that noise.
    Otherwise, just get under the car and start pulling on suspension members to see they move. (Don't pull the car down on top of you though.) Also look for rotted and cracked rubber bushings.
    SE-i Sedan 5 spd
    Our cars have A LOT of bushings. I'm currently trying to track down a noise in the right rear which is sometimes there on bumps, sometimes not. I've replaced both upper arms / ball joints, no change. Grabbing things results in no info, it doesn't happen until a rather sharp bump, and then not always. I'm almost to the point of replacing EVERY damn bushing back there, including the big ones in the swing arms. I have removed everything from the trunk.
    In the front, things seem easier to find. The radius rod (or "strut rod") bushings get worn, and they're a little harder to see. Sometimes when you try to move things by hand under the car it isn't enough compared to the dynamic forces of driving. But I agree, crawl around or put it up on a lift and bang away.
  1. Best and most inexpensive way to improve cornering...
    By krott5333 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-25-2012, 04:36 PM
  2. Cornering and braking issue.
    By 2ndGenGuy in forum 2geez Accords
    Last Post: 06-17-2006, 03:55 PM
  3. blowing blue when cornering hard
    By Vector in forum Carburetor Tech
    Last Post: 02-07-2006, 11:32 PM
  4. Stiffer Ride & Better Cornering
    By DeathRat in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-18-2003, 07:46 PM
  5. Weird Cornering Feeling
    By RCracer in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-01-2002, 07:47 PM
