hey does someone have the wiring diagram,the factory one,that shows the circuit for the recirculate motor and switch? the motor that is mounted on the side of the blower housing? i need that part of the circuit diagram from there to the switch in the heat air control,possibly from a dx,but i can probably figure it out from the pushbutton control one too. i have built an interesting project from one of those door servo motors, but i need to figure out the four wires. the correct wire color codes for the motor are yellow with red,yellow with green,black, and black with yellow. need the diagram from the motor all the way to the switch assembly. if you scan it just send it to [email protected]. thanks!!
