PLEASE TAKE A LOOK AT THE HEADER FAQ THREAD
IF YOU WANT TO BUY INSTEAD OF MAKE YOUR OWN HEADER (CLICK HERE)
1) Choosing Type of Header; 4-1 or 4-2-1
Plan where you want to make power and what kind of driving you will be doing.
Long pipes move the power down in the RPM, Short pipes move the power up in the RPM
- 4-2-1 offers more usable/broader rpm range and often more torque through cylinder pairing.
- 4-1 have longer primaries in most cases moving torque up in the powerband
- Long Tubed 4-2-1 Does the same as a 4-1 but offers the advantage of cylinder pairing.
2) Designing The Header
The stock EFI 4-2-1 manifold and pipe is about 26" long.
The stock Carb manifold is about 10" - 13" long.
4-2-1 Sequential Pairing of cylinders when you have longer primaries like those found on 4-1 headers
4-2-1 Non-Sequential Pairing cylinders then primaries are not as long
Usable Example
Here I did all the equations for you, using multiple sources.
Code:
NON-Sequential 360-DEGREE COLLECTOR 4-2-1 Header For A20A Accord
1) Short Tubed 4-2-1 Design
2) Cylinders 1+4 , 2+3 Paired
3) Small exhaust Diameter for Primaries and Secondaries
4) Long Secondary length after header.
(4 pipe) 1.375" diameter Primaries 18.25" long
(2 pipe) 1.625" diameter Secondaries 12.25" long
Header Length 30.50" long
(1 pipe) 2.000" Secondary pipe 30.50" long
Total lenght 61"
Code:
Sequential 180-DEGREE COLLECTOR 4-2-1 Header For A20A Accord
1) Long Tubed 4-2-1 Design
2) Cylinders 1+3 , 2+4 Paired
3) Large exhaust Diameter for Primaries and Secondaries
4) Short Secondary length after header.
(4 pipe) 1.500" diameter Primaries 36.50" long
Header Length 48.75" long
(1 pipe) 2.000" Secondary pipe 12.25" long
Total Length 61"
Now the muffler after the 61" will be the first LARGE change in cross-sectional area / volume.
This is where return pulse will be created. The muffler must be chambered to allow for the
cross-sectional change as well as flow the appopriate amount of CFM.
In this Case a Hooker Aero Chamber good for 200 HP or 441 CFM with 2.50" inlet and outlet diameters.
You can argue about reducing the 2.50" outlet of the header to 2.25" even 2.00",
but as long as the pipe flows the CFM I need I don't see it hurting much.
The Bit after the muffler in this image is a 2.50" SMSP catalytic convertor.
Bells Formula With Some Minor Tweaks.
Code:
Using EVO of 190 ( Exhaust Valve Opening )
1) HPL = ( ( 850 x ( 360 - EVO ) ) / RPM ) - 3
2) HPL = ( ( 850 x ( 360 - 190 ) ) / RPM ) - 3
3) HPL = ( ( 850 x ( 170 ) ) / RPM ) - 3
3) HPL = ( ( 850 x 170 ) / RPM ) - 3
4) HPL = ( ( 144,500 ) / RPM ) - 3
5) HPL = ( 144,500 / RPM ) - 3
Using RPM 6800
6) HPL = ( 144,500 / 6800 ) - 3
7) HPL = ( 21.25 ) - 3
8) HPL = 21.25 - 3
9) HPL = 18.25
HPL = 18.25"
EPL = 21.25"
Using RPM 6500
6) HPL = ( 144,500 / 6500 ) - 3
7) HPL = ( 22.23076923077 ) - 3
8) HPL = 22.23076923077 - 3
9) HPL = 19.23076923077
HPL = 19.25"
EPL = 22.25"
Using RPM 5500
6) HPL = ( 144,500 / 5500 ) - 3
7) HPL = ( 26.27272727273 ) - 3
8) HPL = 26.27272727273 - 3
9) HPL = 23.27272727273
HPL = 23.25"
EPL = 26.25"
Using RPM 3600
6) HPL = ( 144,500 / 3600 ) - 3
7) HPL = ( 40.13888888889 ) - 3
8) HPL = 40.13888888889 - 3
9) HPL = 37.13888888889
HPL = 37"
EPL = 40"
EPL = (HPL + 3)
USING EPL = 26.25 ( Exhaust Pipe Lenght )
CID Equation
1) HPD = ( ( SCID x 16.38 ) / ( EPL x 25 ) ) x 2.1
2) HPD = ( ( 29.75 x 16.38 ) / ( EPL x 25 ) ) x 2.1
2) HPD = ( ( 487.305 ) / ( EPL x 25 ) ) x 2.1
3) HPD = ( 487.305 / ( 26.25 x 25 ) ) x 2.1
4) HPD = ( 487.305 / ( 656.25 ) ) x 2.1
5) HPD = ( 487.305 / 656.25 ) x 2.1
6) HPD = ( 0.74256 ) x 2.1
7) HPD = 0.74256 x 2.1
8) HPD = 0.74256 x 2.1
9) HPD = 1.559376
HPD = 1.50"
1) HPD = ( ( SCID ) / ( EPL x 25 ) ) ) x 2.1
2) HPD = ( 487.305 / 765.625 ) x 2.1
3) HPD = ( 0.63648 ) x 2.1
4) HPD = 0.63648 x 2.1
5) HPD = 1.336608
HPD = 1.375"
CC Equation
1) HPD = ( ( SCC ) / ( EPL x 25 ) ) ) x 2.1
2) HPD = ( 488.750 / 656.25 ) x 2.1
3) HPD = ( 488.750 / 656.25 ) x 2.1
4) HPD = 0.744761904762 x 2.1
5) HPD = 1.564
HPD = 1.50"
2) HPD = ( 488.750 / 765.625 ) x 2.1
3) HPD = ( 0.638367346939 ) x 2.1
4) HPD = 0.638367346939 x 2.1
5) HPD = 1.340571428572
HPD = 1.375"
119 cid
SCID = 29.75
1955 cc
SCC = 488.750
Other Formula
Code:
40.592” (7500 RPM 210 EXH DURATION)
42" - Out of Tune
- 43"
--- 44"
----- 46" (6500 RPM 210 EXH DURATION)
------- 48" (AVERAGE 210 EXH DURATION)
--------- 50"
----------- 51" (7500 RPM 253.5 EXH DURATION)
--------- 52"
------- 54"
----- 56"
--- 58" (5500 RPM 210 EXH DURATION)
- 59"
--- 60" (AVERAGE 253.5 EXH DURATION) (6500 RPM 253.5 EXH DURATION) (7500 RPM 288 EXH DURATION)
----- 62"
------- 64"
--------- 66"
----------- 67"
--------- 68"
------- 70" (AVERAGE 288 EXH DURATION) (6500 RPM 288 EXH DURATION)
----- 72" (5500 RPM 253.5 EXH DURATION)
--- 74"
- 75"
76" - Out of Tune
83.78” (5500 RPM 288 EXH DURATION)
Remember the engine moves in and out of tune
throughout the RPM range so I did averages
instead of going strickly based one setting.
The "OUT OF TUNE" I added to set limits based on averages.
Then I did calculations @ different rpms @ different exhaust durations.
If you look how the 288 @ 5500 rpm droped below the out of tune...
I'm figuring this is because such a high duration was not ment for
such a low rpm.
So I assume building a header with that length would do more harm
then good. Or not.
Comparison Between Chart and Bells Formula Figures.
Code:
EPL ( Exhaust Pipe Lenght )
EVO ( Exhaust Valve Opening )
Optimum EPL using EVO of 190 and RPM range of 3600-6800 is 30.625" with optimum diameter of 1.375"
When trying to find the collector outlet diameter, use about a 20% larger pipe than the primary header pipe diameter on 4cylinder motors.
1-3/8" _or_ 1.375" + ( 1.375 x 0.20 ) = 1.65" which is close to 1.75" collector diameter
1-5/8" _or_ 1.625" + ( 1.625 x 0.20 ) = 1.95" which is close to 2.00" collector diameter
1-3/4" _or_ 1.750" + ( 1.750 x 0.20 ) = 2.10" which is close to 2.00" collector diameter
2.000" _or_ 2.000" + ( 2.000 x 0.20 ) = 2.40" which is close to 2.25" collector diameter
On V8's use collector equations as follows.
1.375" x 1.750" ~ 2.50 Collector
1.625" x 1.750" ~ 2.75 Collector
Header Plus Secondary Pipe Lenght | Header Lengths
51.75" (5500 RPM 190.00 EXH DURATION) EPL = 25.875" (using Other Formula) vs. EPL = 26.25" (using Bell's Formula)
58.00" (5500 RPM 210.00 EXH DURATION) EPL = 29.000" (using Other Formula) vs. EPL = 26.25" (using Bell's Formula)
72.00" (5500 RPM 253.50 EXH DURATION)
83.75” (5500 RPM 288.00 EXH DURATION)
40.25" (6500 RPM 190.00 EXH DURATION) EPL = 20.125" (using Other Formula) vs. EPL = 22.25" (using Bell's Formula)
46.00" (6500 RPM 210.00 EXH DURATION) EPL = 23.000" (using Other Formula) vs. EPL = 22.25" (using Bell's Formula)
60.00" (6500 RPM 253.50 EXH DURATION)
70.00" (6500 RPM 288.00 EXH DURATION)
Code:
Header
Primary lenght,
lenght of 4 and 2 pipes on 4-2-1
or lenght of 4 primaries on 4-1.
Primaries,
length of 4-2 pipes.
Secondaries,
length of 2-1 pipes.
Collector length,
length of pipe after 4-1 primaries merge.
Exhaust
Secondary length,
length of pipe after primaries but sometimes including
part or all of collector length. Secondary length is said
to be important in making torque, even more so than
primary length.
Total length,
Lenght of Primary and Secondary together
Primary , Secondary
Lenghts | RPM
________________________________
28.375 - 26.000 | 6500 - 7000
30.000 - 28.375 | 6000 - 6500
33.625 - 30.000 | 5500 - 6000
36.000 - 33.625 | 5000 - 5500
Code:
The basic ideas for building a header are:
1) Broaden power over a wide power band, not
just tune for high narrow peak power ( HP / Toruque )
2) Maintain exhaust velocity (scavenging vacuum)
3) Lower Backpressure as much as possible
Code:
TIPS:
Dont port your exhaust port to match the header flange,
a 1mm larger flange port all the way around will allow
the exhaust port on the head to act as an anti-reversion dam.
AR or anti-reversion is any area inside a pipe that allows
flow in one direction while inhibiting blow in the reverse direction.
AR is mostly used to address reversion at low engine speeds
where long duration cams cause the air/fuel mixture to get contaminated
by reversion.
Another Formula :
L = (850 X ED) / RPM
L = length of primary pipes in inches
ED = 180 degrees + number of degrees exhaust valve opens BBDC
RPM = engine RPM at peak torque
Secondary Length approximately 2/3 Primary Length
Mine
Justins
