Ok so I'm hearing a noise in my front driver wheel. It sounds like air coming out when I'm driving. When I hit the brakes it stops. when I turn the wheel it gets louder.
Well damn![]()
Maybe its your brake disk guard thingy? Sometimes they get wacked out and start rubbing on the brake disk.
oh my bad, disc guard is not brake hardware ~~~but you can pry it out of the way without taking the wheel off so I am just e -tard-derd
Bitesize maybe thats what it is makin the noise but the f$%^ing pads squeal when applied and they're not even to the squealers. IDK![]()
my brakes make noise when cold....does it do it all the time or cold/hot
Seems like when they get hot it does it.
if it happens every day most likely your calipers are hanging up (need a rebuild)
if it's only on some days or in the morning it's probably surface rust.
other possibilities are a worn wheel bearing (makes your car sound like you have offroad tires) or a wire dangling on the axles.
if the dust shield is rubbing the disk it will leave a slight groove in the disk that you can see on the inside face.
Eric
