Results 1 to 3 of 3
Thread: 88 Accord Dx stalling
    Apr 2008
    Exclamation 88 Accord Dx stalling
    88 Accord DX Carb................Car starts fine and runs great for about 10 minutes. If you have the vehicle in gear and driving the car will completely shut off. Pull over to the side of the road and wait a minute or two and the car starts right up and you can drive again. Same thing happens again. After the second time the car stalls you can crank it up and not drive but leave the car in park and rev the engine to 3000 rpms and within a minute or so the car will start stalling and sometimes you can pump the gas and baby it back to life and sometimes not. The car has continously restarted within two minutes after each and every stall. I have replaced the fuel pump, rebuilt carb, new fuel filters, ECU *computer*, distributor (cap,plugs,wires,all of it), ignition control module, and coil. Any ideas would be greatly appreciated as this problem has left about 5 mechanics scratching their heads.
    LX User evil88accordLX's Avatar
    Jul 2007
    gold 88 accord lx
    NWA (not the rap group)
    Re: 88 Accord Dx stalling
    check your vacuum lines. mine was doing something similar, without the stalling. it would try to die after it was warmed at intersections. it ended up being the line that goes from the carb to the flapper door on the air cleaner. i couldnt see that the line was disconnected because it was under the air cleaner. anyways, as soon as i plugged it back in the car ran like new again.
    Apr 2007
    1988 Accord LX 5spd
    Might be the fuel pump relay.
  1. Stalling issue ('87 Accord LX)
    By Snowfox in forum 3geez Accords
    Last Post: 08-05-2012, 11:34 AM
  2. 87 Honda Accord idling/stalling issues
    By aeongap in forum 3geez Accords
    Last Post: 08-19-2005, 03:58 AM
  3. Replies: 2
    Last Post: 04-16-2005, 02:47 PM
  4. Stalling Problem - 88 accord
    By DCD1278 in forum 3geez Accords
    Last Post: 06-03-2004, 08:00 PM
  5. 88 accord stalling/missing
    By grappler88 in forum 3geez Accords
    Last Post: 04-10-2004, 08:52 AM
