Results 1 to 8 of 8
Thread: Need some help!
    LX User crucial's Avatar
    Sep 2007
    1988 Honda Accord LX
    Reno, NV
    Exclamation Need some help!
    K i got my new motor in and running but the temp gauge on the instrument panel is not working and the fans on the radiator are not coming on like they should, also im not sure which hose goes were from the heater core to pipe and intake manifold to pipe, does the intake go to the pump or to the pipe? The heater core would go to the other.
    Sep 2007
    Reno, NV
    Re: Need some help!
    well i just figured out the hose routing thanks to some images on hondapartsdeals, but still am looking for some help on the temperature issues
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    Re: Need some help!
    HAH carb nvmd
    Re: Need some help!
    the switch for the fans is at the bottom of the radiator, unplug it turn on the key and jumper the two wires,if the fans come on it's the sensor. the temp gauge uses a small sensor at the back side of the intake manifold, it has one wire going to it,see if you knocked off the wire putting in the engine.
    Re: Need some help!
    Since you up pretty high your fans might come on. Mine never ever do unless I go driving in the mountains at elevations over 2500'. The normal idling with the hood up I can't see them ever coming on unless the base temps like over 100F outside.
    If you have AC buttons you can use them, button then fan on, to make both fans come on manually also. Even with the 10 amp AC fuse pulled that fans come on in my car even if the compressor does not.
    Sep 2007
    Reno, NV
    Re: Need some help!
    Can someone tell me what color wire goes to the temperature switch on the back of the intake and what is the sensor \ switch on the motor by the oil filter?
    Sep 2007
    Reno, NV
    Re: Need some help!
    Could someone look on there motor and see what colors the wire is?
    Sep 2007
    Reno, NV
    Re: Need some help!
    Well i found out what wire goes to the temperature gauge on the back of the intake if any one wants to know its yellow and green.
