Results 1 to 10 of 10
Thread: tranny shift problem possably bad tranny
    DX User xxxfrankensteinxxx's Avatar
    Jan 2008
    88 accord dx gone- new toy 91 accord ex
    wisconsin
    well my car was shifting odd before sometimes i had to let off the gas before it would shift, now it will start up shift fine maybe half hour later it will quite working except chug at 8000 rpm and only reverse works any ideas? its parked in my driveway since I'm to afraid to drive it. its auto carbed
    Re: tranny shift problem possably bad tranny
    Fluid change, and why the hell did you get up to 8,000rpm? I am not even sure that is possible even with a carb(stock setup)
    Jan 2008
    wisconsin
    I've went past 8000 but only for a few seconds cause it was in the middle of road. I'll try a fluid change i did one not to long ago but well see
    Also, check the TV cable adjustment.
    Jan 2008
    wisconsin
    gonna do a tranny flush tomorrow is it safe to use a a air compressor to blow it out? also im putting in some lucas hope it helps, will also check adjustment
    From what I hear Lucas doesn't really help, but I could be wrong. I wouldn't use an air compressor, you may blow some crap into areas where it will really harm the tranny.
    Quote Originally Posted by xxxfrankensteinxxx View Post
    I get the feeling you are about to make a big mess of your tranny. Take it to a shop have it properly flushed.
    I was thinking the same. Best thing to do is drain the fluid. Pour some fresh fluid in, drive it around for a little bit, and repeat several times.
    yeah they have special machines that do flushes or do the russiankid way if you have enough money for 2 or 3 flushes.
    Jan 2008
    wisconsin
    thanks guys i didnt do the air compressor just threw it up on ramps and drained her, threw in some lucas at first and topped her off with some castrol, she was leaking out ot the tranny at first but after i started her up i havent noticed any leaking and has been running fine, still gotta adjust the shifting tho, next up is motor oil change lol thanks guys,
  1. what makes an auto tranny shift?
    By evil88accordLX in forum 3geez Accords
    Last Post: 04-29-2008, 08:16 AM
  2. hard shift - linkage or tranny?
    By jayshonda in forum 3geez Accords
    Last Post: 03-21-2005, 10:35 PM
  3. Replies: 4
    Last Post: 02-21-2005, 06:34 PM
  4. Hard shift into reverse w/ auto tranny
    By 98serwtricks in forum 3geez Accords
    Last Post: 04-06-2004, 09:36 AM
  5. Replies: 3
    Last Post: 06-17-2003, 04:54 PM
