I don't see how the idle would be effected. Unless the AC idle booster is supposed too bring the idle back were it was originally when the lights are on as suggested in A 2001's article on idle adjustment see below quote.
5) Keep the headlights and fans on and also turn on A/C
Adjust the A/C idle boost to raise the idle speed back up to where the idle speed was prior to the A/C being turned on.
BTW when I say turn on the A/C it should be at full blast.
After the A/C idle boost is set you're all out of adjustment screws... at least ones for idle after the cold start process.
