Results 1 to 11 of 11
Thread: Brakes rub
    SEi User turabaka's Avatar
    Aug 2007
    Boise, ID
    Brakes rub
    Alright I've got a little problem that hopefully you guys can help me fix. I noticed the other day that my front right brake rubs a bit. It's kinda of a pulsating rub, so I figured that it's either old pads or a warped rotor. I went out, and bought a new rotor, and pads for the front. Now after I installed them, both of my front brakes rub. Any ideas on what's going on? Normal for them to rub at first, or is there something I should do about it?
    Re: Brakes rub
    Did you clean and grease the caliper pins? I am pretty sure they will rub slightly, as long as they do not drag.
    Aug 2007
    Boise, ID
    Re: Brakes rub
    I did not. I guess I can go and try that, and see if it fixes anything.
    Re: Brakes rub
    Make sure to clean out the inside of the caliper bracket and put some grease in there as well as grease the pins themselves.
    Idaho
    Re: Brakes rub
    They did that when they were on my car.
    Aug 2007
    Boise, ID
    Re: Brakes rub
    ^^ hmm... I'd figured that it was probably a warped rotor, since the one that was rubbing had some pretty deep scores in it. I'll go out, and tear it apart again, and regrease everything.
    Idaho
    Re: Brakes rub
    It's most likely the calipers. Were the old brake pads evenly worn on both for each side? I had those front brakes done at les schwab about 3 years ago. Maybe had about 5,000 on them.
    Aug 2007
    Boise, ID
    Re: Brakes rub
    naw. I figured out what it was. The dust shield on the right side had a small cut in it, and was bent out. So that was rubbing against the rotor causing the noise. I just hammered it back in and put it all back together. I still put new grease on the caliper pins, and cleaned everything off as well though. They sound much better now.
    Re: Brakes rub
    i need to get my legend front end swap...cuz i can hear my pads rubbing on my slotted rotors
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    Re: Brakes rub
    love the sound drilled/slotted rotors make
    nice whizzy sound
    Re: Brakes rub
    Yeah the pins are that source of the rattling sound over small bumps at slow speeds.
  1. Big Brakes and Addco rear sway bar on sei brakes
    By EricW in forum Classic Honda Pics & Videos
    Last Post: 10-01-2007, 01:13 PM
  2. got the brakes in
    By alboy86 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-26-2007, 09:46 AM
  3. no brakes
    By 89HondaLxi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-03-2005, 09:50 PM
  4. Switching carb brakes to EFi brakes...
    By Hash_man_Se_i in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-21-2005, 04:09 PM
  5. brakes.... my kingdom for new brakes
    By 89accord_lxi_coupe in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-02-2003, 04:11 AM
