after reading hazwans thread i looked in my fusebox too. and what did i find?
EUREKA! this would be that "soldering" smell that regularly but intermittently wafts up my nose when im driving home at night. i removed the fuse, the worn inscription reads "30A"
i tried the lights: -sidelights -brakelights -indicators -lowbeams -...
no high beams. when i pull the lever i get darkness, so this fuse is THE direct inline high-beam circuit fuse, right? and thats probably the highest-wattage accessory in the car.
when i got home i opened the fusebox, which was quite warm, and brushed my finger over the fuses, all of which were slightly warm except this one, which was too hot to touch. i have a 5th light, a big halogen spot on the bumper, which is relay-triggered by the high-beam circuit but wired separately to the battery as far as i can tell [by a previous owner but i liked it]. i turned it off anyway for the trip home, so that leaves only the 4 normal ones...
which arent quite normal i suppose. when one died, i swapped them like a lot of other stuff in my car for the 1981 equivalents. i dont think they were rated substantially higher though... maybe 5w more. is that enough to melt fuseboxes, considering its really the same car?
the wires leading to and from the fuse are ok. so i guess its the fuse itself getting really hot... but not blowing. what are your high-beam fuses inscribed with, and do they get hot? if i put in a bigger fuse, it'll just melt the next weakest link, right? it shouldn't be melting anything at all, should it?
plz help, for the good of nocturnal wildlife.
