This isn't Accord related, hell its not even a Honda lol. Anyway. I replaced my dad's Feroza master brake cylinder as it was leaking past the rear seal since the bore is badly corroded/pitted with a new one. I did exactly what the manual said: drain all the fluid from front and rear, disconnect all the lines to the master, take it off, put a new back in.
I've manually bled the whole system using the 2 person method as I can't find any bleeding kits for like 100 times and the pedal still soft, which means theres still air in the system right?
I didn't bench bleed the new master as I don't have any spare lines around and couldn't find any kits I thought it isn't really necessary since the manual didn't mention anything about bench bleeding the new master.
I know how to bleed, I've done it several times before and all working perfectly fine. Is there anything else I'm missing?
