It is a sad day.
The 86 does not idle right once warmed up.
I don't know why this is happening. I don't think its a vacuum issue because the issue is only once the car has reached normal operating temperature. RussianKid tested the vac pressure a few weeks ago and I believe it was normal. I can drive it like I stole it but once I take it out of gear the idle just sinks straight to 200-250RPM's and usually stalls out. Upon looking at the engine, you can almost see the words on the drive belts as they go by, they move that slow. No warning lights on the dash, so I do not think it is alternator/battery related (both are fairly new).
I looked for loose connections but that doesn't seem to be an issue.
Russain suggested that the spring on the idle screw might not be putting out enough pressure on the screw and that it may need to be pulled out and stretched.
When the car is cold/has not be started for a few hours (time to cool off), it fires up and holds a steady 2kRPM until I bump the accelerator to get it to go down, and even then it drives normally. The issue is only when hot.
I thought maybe the t-stat but the needle is showing what seems to be normal temps.
281k and this is the gift in return!
FYI - When it does die, it fires right back up with no issue, but idles low or/and stalls again.
