Results 1 to 16 of 16
Thread: Finally got the wideband on.
    May 2004
    Idle is around 11.8-12.2, cruise is low 13s, WOT is 10.4s
    Gonna drop 1 size in the main, 2 sizes on the secondary and go from there. The idle kind of trips me out - as the idle is smoother with the 75 idle jet, but my current AFRs are with a 70 idle jet.
    Fun times
    May 2004
    Re: Finally got the wideband on.
    Just changed to a 75 idle, 135 primary, 140 secondary.
    Idles ~12.8 (screwed the screw in some)
    Cruises ~14.0
    WOT ~11.5
    Needs to be leaned out more
    what are you other sizes, emulsion tubes? 75 seems kinda tall on the Primary idle jet, I dunno
    Main Jet =
    Secondary Main Jet =
    Air-Correction Jet =
    Secondary Air-Correction Jet =
    Idle Jet =
    Secondary Idle Jet =
    Accelerator Pump Jet =
    Primary Emulsion Tube =
    Secondary Emulsion Tube =
    May 2004
    Go check the 'Post your 32/36 jet sizes!' thread - I keep all of my tuning notes in my loooong post at the end of it
    dam I was there and didn't even check, my bad
    89T's Avatar
    Apr 2004
    seems like you'r getting pretty close...
    i'd try bumping the timing a lil bit before you change the them out.
    un-motivated!
    3GR
    May 2004
    Why? What's the timing curve of the stock A20 anyway?
    2ndGenGuy
    Guest
    What WBO2 setup did you get? Or did I miss that thread?
    May 2004
    I've had it for a couple years - Zeitronix ZT-2, I love it.
    group buy way back yonder.. lol
    https://www.3geez.com/forum/showthread.php?t=40357
    cygnus x-1's Avatar
    Chicago area
    Quote Originally Posted by Doward View Post
    Cruises ~14.0
    WOT ~11.5
    That's about perfect for idle. Cruise could be leaner but you'll probably get lean surge if you go past 16:1. I'm running at about 16.5:1 at cruise right now and I can feel it just starting to surge a little. 12.5:1 would be good for WOT. Also don't forget you can mess with the air corrector jets to tweak the high RPM mixture without affecting the mid range. A larger air corrector with lean out the mixture at higher RPMs.
    C|
    May 2004
    Finally getting around to swapping the jets this morning. I'll post later with the results
    May 2004
    130 pri, 135 secondary, 180 air correctors on both -
    ~13.5 idle
    ~15.0 cruise
    ~12.5 WOT
    I'm going to drive it around a couple days. Then I'm going to go 175 primary air correctors, and 185 secondary air correctors, to see what happens
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Thanks for keeping us posted
    89T's Avatar
    Apr 2004
    Why? What's the timing curve of the stock A anyway?
    don't know! but trust me play with the timing too.
    remember you are looking for the sweet spot on your motor...
    un-motivated!
    3GR
    May 2004
    175 pri air, 180 sec air, same jets as before, with a 70 idle jet now.
    Weird, the lower I get the idle (down to 300-400 rpm) the richer the idle gets - but as I bring the idle back up, the idle leans out.
    Idle: 12.0
    Cruise: 14.7-14.9
    WOT: 11.5
    I need to lean the secondaries out more. 185 air correctors going in later.
  1. using clock display as wideband gauge
    Last Post: 10-12-2016, 07:38 PM
  2. Innovate Wideband thread
    By Oldblueaccord in forum Performance
    Last Post: 10-20-2009, 02:03 PM
  3. Wideband O2?
    By itzdave in forum Performance
    Last Post: 07-24-2009, 05:33 PM
  4. Wideband O2 in the egr port
    By Oldblueaccord in forum 3geez Accords
    Last Post: 10-19-2007, 04:35 PM
  5. Wideband 02
    By w00tw00t111 in forum Performance
    Last Post: 03-09-2006, 06:20 PM
