i heard that the b20 head will fit the a20.. true?
-Tom
1988 4 Door Lx-i 5-speed
364,XXX and counting :]
good god man. Sorry to flame, but Jesus Christ on a piece of toast learn to read. Five minutes in the performance section or with the search button could have gotten you the answer.
your answer is no
will do gentlemen.. thanks for the input
well i guess ill change the thread up a bit.. my efi 87 is running really rough at idle.. idles around 800 then gradually dropps to 500-400 and blows black smoke then shoots up to 800 and smoke stops... does this repeatedly.. any ideas why?
-Tom
to bad we could not make a adapter but the compressions dif would suck lol
-Tom
do a fuel filter,air filter,plugs and set the timing etc and see what happens
always worht doin a basic tune as part of a poor running fault.
and check the idle air control valve and see if she workin right
https://www.3geez.com/forum/showthrea...ighlight=codes
06 LED FLASH(s) 85-98 Accord
ECT Sensor (Engine Coolant Temperature)
defective circuit or unplugged / defective sensor
