Results 1 to 25 of 27
Thread: A20A3 head question
    May 2008
    los angeles
    Exclamation A20A3 head question
    i heard that the b20 head will fit the a20.. true?
    -Tom
    1988 4 Door Lx-i 5-speed
    364,XXX and counting :]
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    Re: A20A3 head question
    Quote Originally Posted by 1987AccordLx-i View Post
    -Gio
    My E85 Turbo Build
    5280FEST
    x2
    SEi User turabaka's Avatar
    Aug 2007
    Boise, ID
    good god man. Sorry to flame, but Jesus Christ on a piece of toast learn to read. Five minutes in the performance section or with the search button could have gotten you the answer.
    May 2008
    los angeles
    im new to the site so im still learning the features.
    -Tom
    no offence but the search button is just as easy to click as the post new thread button...
    welcome to the site but please do seach some before makeing new threads on items allready talked about
    snoopyloopy's Avatar
    Killa Cali
    your answer is no
    A Mile High.
    your answer is no
    the question hasnt really been answered YET
    -Gio
    My E85 Turbo Build
    5280FEST
    May 2008
    los angeles
    no offence but the serch button is just as easy to click as the post new thread button...
    will do gentlemen.. thanks for the input
    well i guess ill change the thread up a bit.. my efi 87 is running really rough at idle.. idles around 800 then gradually dropps to 500-400 and blows black smoke then shoots up to 800 and smoke stops... does this repeatedly.. any ideas why?
    -Tom
    A Mile High.
    sounds kinda like a distrubutor problem? my moms minivan would idle like that and kinda backfire, it would go rich and crap (black smoke). it was the distributor.
    -Gio
    My E85 Turbo Build
    5280FEST
    its not gona be a simple bolt on project so the answer is no lol
    A Mile High.
    well he asked i it would fit, not if it was simple lol
    -Gio
    My E85 Turbo Build
    5280FEST
    to bad we could not make a adapter but the compressions dif would suck lol
    he asked if a b20 head would fit a a20 block as fare as i know they dont fit lol
    edit: sorry they fit but dont line up quite right due to oil lines
    A Mile High.
    well from what ive read, the head need some machining and other crap, but it should bolt on... with lots of work...
    -Gio
    My E85 Turbo Build
    5280FEST
    May 2008
    los angeles
    hmm.. i changed the cap,rotor,wires,plugs and she still does it.. would it be a sensor? thats all i can think of as the rest of the dist. is just the vac advance and the shaft coming from the cam turning the rotor
    -Tom
    May 2008
    los angeles
    correct.. the oil lines dont line up and something about the headbolts not lining up
    -Tom
    A Mile High.
    does the check engine light come one?? check your ecu for codes... maybe o2 sensors? injectors?
    -Gio
    My E85 Turbo Build
    5280FEST
    SEi User Hauntd ca3's Avatar
    Sep 2007
    1988 ca3 si exclusive
    new zealand
    do a fuel filter,air filter,plugs and set the timing etc and see what happens
    always worht doin a basic tune as part of a poor running fault.
    and check the idle air control valve and see if she workin right
    May 2008
    los angeles
    yeah im getting 6 flashes from the ecu.. someone told me that its a temp sensor or something in that area of coolant sensing
    -Tom
    May 2008
    los angeles
    i did the air filter and plugs.. but i do have to swap the fuel filter and get it timed.. im thinking its off a lil.. and when i punch it off the line.. she hesitates then hauls ass
    -Tom
    A Mile High.
    https://www.3geez.com/forum/showthrea...ighlight=codes
    06 LED FLASH(s) 85-98 Accord
    ECT Sensor (Engine Coolant Temperature)
    defective circuit or unplugged / defective sensor
    -Gio
    My E85 Turbo Build
    5280FEST
    May 2008
    los angeles
    sweet... so do you know which one it is cuz theres a white one and a green one.. i just wanna buy one.. i dont wanna buy it and it not be the defective one
    -Tom
    A Mile High.
    i have no clue, sorry...
    -Gio
    My E85 Turbo Build
    5280FEST
  1. A20A3 head on a1
    By mephi in forum 3geez Accords
    Last Post: 02-03-2009, 05:09 PM
  2. FS: A20A3/BT head
    By AZmike in forum Trading Post
    Last Post: 04-01-2004, 11:53 AM
  3. BS1 head to A20A3
    By Not like a rock in forum General Engine Swaps
    Last Post: 03-18-2004, 07:48 PM
  4. i need a A20A3 head plz
    By 89LXIHATCH in forum Trading Post
    Last Post: 06-27-2003, 04:29 AM
  5. a20a3 head
    By Experimental_Honda in forum General Engine Swaps
    Last Post: 10-22-2002, 07:32 AM
