sweetness.. did you get a new cam? you're getting better at composing shots![]()
loving it! when are u going to do the rear disk pico?
kodak z710 I've had it for almost 2yrs now, not the best but it does good for me.
I started to take my time with the shots instead of rushing
Im debating on the rear disk swap. I really want to get a rear ST sway bar but the ones Ive seen are for rear drum setup
you don't think it will work with the disk in there?
i thought it worked with the discs O.o?
i'm pretty sure that was the addco rear swaybar
the ST should fit, you could test fit mine maybe?
I don't see how the brakes would prevent the sway bar from fitting. The rear disc's do not take up more room than the drums.
sick ride man!!! 10 stars!! where did u get ur window visors?
