Results 1 to 8 of 8
Thread: Cleaned my "Idle control valve"
    Dec 2003
    Millington, TN
    Well yesterday, after much research to my question. I found that a number of people were cleaning their Idle control valve (EACV).
    I removed it (Do Not Remove Valves) cleaned with throttle body cleaner to remove all the carbon, opened the coolant port, to my surprise it was coated with rusty, coolant sludge.
    I used a air compressor to ensure that everthing dried completely.
    Reassembled useing blue RTV to coat the coolant port gasket and copper coat to coat the valve port gasket.
    And today it was not trying to stall out with the A/C engaged when stopped or coming to a stop.
    This is a must do if you have low RPMs under A/C load.
    Phil
    Re: Cleaned my "Idle control valve"
    Use O2 sensor safe RTV on this if you have to use RTV. I am sure you need to use very much and careful not to have excess.
    Dec 2003
    Millington, TN
    Not really, the coolant chamber is completely isolated from the valve chamber.
    I only used a thin coating to only fill any gaps the gasket couldn't because of age.
    Phil
    ahhh I see, says the blind man
    sorry for the confusion, I just wanted to note that about using RTV on the intake side. As long as it is isolated in the coolant side it is not really an issue.
    LX User bank2me's Avatar
    Apr 2008
    88 Accord LX-i
    Portage, WI
    I should clean mine, it goes to low rpms if the lights go on or if the fans kick on
    Dec 2003
    Millington, TN
    Quote Originally Posted by bank2me View Post
    I would have your alternator checked, a weak RF signal is the #1 check for electrical load low RPMs.
    But it would do any harm cleaning the EACV (Idle Control Valve)
    Phil
    Dec 2003
    Millington, TN
    Good point.
    Phil
    im going to be cleaning mine out aswell (Y)
  1. Painted my valve cover - "Gunmetal Hammed"
    By frantik in forum Classic Honda Pics & Videos
    Last Post: 06-20-2007, 07:21 PM
  2. Finally got my "CRUISE CONTROL" back
    By nswst8 in forum 3geez Accords
    Last Post: 10-21-2004, 04:08 PM
  3. Heater Control "Mode" Cable Repair
    By DeathRat in forum 3geez Accords
    Last Post: 02-01-2004, 07:43 AM
  4. "putting" sounding exhaust at idle
    By danronian in forum EFI Tech
    Last Post: 09-16-2003, 06:24 PM
