Okay, a buddy of mine and I are trying to wire my car and are having a hard time finding a place to run a 4 gauge power cable through the firewall. Any help or ideas?
umm i ran mine on the pass side under the black box i just drilled a hole trough the firewall there is also a hole right behind the intake thats got a plug in it that comes out right behind the dash
Uhhhhhhh... I don't know if this was stock, but there was a grommet directly underneath the black box... I ran 4awg from the engine bay to under my passenger seat
i had to drill a hole on mine
mine goes thru the pedals.....my amp does 454rms....knock hard...
i drilled a hole too and im running 2awg at the moment
1988 accord lxi SMASHED 225k havent seen it in sooooo long AND GOIN STRONG!!!!!!!
there should be a rubber grommet on the drivers side in firewall to sneak it through
I ran mine thru a grommet hidden in the passenger side fender well. There was a hole for wiring almost under the fuse box, next to the factory intake tube. I split loomed it for protection until it was in the cab. Followed the factory wiring into the cab and ran it under the panels along the door jams, then into the trunk. I figured if Honda put their wires there why not.
I think there was a huge hole on the firewall by the foot pedals, I ran all kinds of shit through that hole.It's larger than an inch in diameter, so should easily accommodate a little power wire like that.
I used to the grommet Geddy was talking about. Worked perfectly. Wrapped it in a loom and nobody will ever know what it does(hiding ugly blue Scosche shit ftw.)
