Hmm... I don't know if it's just my clutch, or most 3G's, but I noticed my clutch is very stiff, but not very grippy...
If I am not all the way down on the pedal, it doesn't release and let me shift very easily. But problem with power shifting. BUT! My clutch only has about an half an inch of free-play before I hit pressure plate.
When I had the engine out, I resurfaced the flywheel and checked out all the clutch components. Everything looked good... I pushed the clutch and it was very easy to push. I moved the clutch lever in and out. That was easy. I guess my pressure plate is pretty stiff...
BUT the reason for this post is...
Would it be bad to Customize the clutch lever, as in shorten it?
