Page 2 of 2 FirstFirst 12
Results 26 to 48 of 48
Thread: oil light flashing... help?
    Re: oil light flashing... help?
    Quote Originally Posted by 1987AccordLx-i View Post
    can i have a list of engines that will??
    a16a1
    a18a
    a18a1
    a20a
    a20a1
    a20a2
    a20a3
    a20a4
    b20a
    b20a1
    b20a2
    b20a8
    bs
    bt
    and those other ones i cant remember the names of
    May 2008
    los angeles
    a16a1
    a18a
    a18a1
    a20a
    a20a1
    a20a2
    a20a3
    a20a4
    b20a
    b20a1
    b20a2
    b20a8
    bs
    bt
    well done.. question number 2.. which is the most powerfull and easiest to obtain? im in the us so emissions is a bitch here
    -Tom
    1988 4 Door Lx-i 5-speed
    364,XXX and counting :]
    well the 88-89 a20a3 is rated for 122hp...its the easyest to get here...the only diff bettween the 86-87 is a better flowing exhuast manifold and intake manifold...but you can just get headers and call it a day
    LX User evil88accordLX's Avatar
    Jul 2007
    gold 88 accord lx
    NWA (not the rap group)
    being that you are in Cali., isnt there a law about swapping in a different engine in your car anyhow? i would think that limits you to the A20A3. i could be wrong on this, but i thought i had read that on here somewhere before. here in Arkansas, we dont even have inspection! you could drop a tank engine in it if you really wanted.....
    i believe it just has to be the same year or newer then the car,and it has to have all the emissions equipment for that engine,also if it's a carb and you go fuel injection,it has to have the check engine light put in, and the diagnostic harness, if i remember correctly you go to a referee there for emissions,if you can show that the swap engine has all the proper equipment and the correct converters for that engine you shouldn't have too much problem.
    May 2008
    los angeles
    guys... the unthinkable just happened today.. im getting on the freeway and i notice i dont have much power.. so i think that its just a little hot.. so then i get off the freeway and the oil light starts blinking again.. i stop and check the oil level.. its fine.. then i hear knocking coming from the bottom end and head.. i get to my friends shop and he tells me that this motors done.. anybody know where i can get an A20A3 for an 87 here in LA?
    heres a link to a vid i made of the noise... please let me know whats going on... im getting so many freakin answers its confusing...
    http://www.youtube.com/watch?v=3bq3t0e6Qrw
    -Tom
    Yeah its blown. Rod or the pin. Sorry for you prolly not much you could have done about it.
  8. #33
    May 2008
    los angeles
    dam that was my worst fear... well thanks for the honesty man.. ill just drive her till her last rev.. then ill get the new motor
    -Tom
  9. #34
  10. #35
    May 2008
    los angeles
    to the max
    -Tom
  11. #36
    Not much else you can do.Maybe try thick oil or some additives to milk it along. Carry a cell phone and a wrecker drivers card in your wallet
    Evans autoparts here near me prolly still has motors but I dont know if they truck ship or not.
    Down and dirty if your real ambitious you can pull the oil pan and fix the bad bearing,change the oil pump. Its what I call a redneck rebuild.
  12. #37
    your engine bay may get very dirty when it goes (if it suddenly goes) otherwise it may just seize. I notice your the guy that asked me on youtube about getting a digidash and B20A engine. lol
    i reckon you try and pick up a cheap; parts car and steal the a20a whatever engine from it, put all your intake and exhaust manifolds on it and you should be sweet if the parts car engine runs mint. you should consider a 5 speed swap also
  13. #38
    Major bummer man. Just stay away form Engine World, LLC here in Emeryville. They ship, but the guy's a real jerk.
    To wit:
    https://www.3geez.com/forum/showthrea...gine+world+llc
  14. #39
    how do you know it's the engine? if the pump goes and too little pressure bearings will knock also
  15. #40
    May 2008
    los angeles
    well if i was getting too low oil psi... then wouldnt the light start flashing again??? besides this shit knocks beyond belief! i never knew sounds like that could come from the engine.. it sounds like a hammer being struck against concrete!
    -Tom
  16. #41
    are you sure you don't have a broken rod or busted crank or something? i've seen engines running with half a crank before, or if it broke a rod,this would explain why down on power, might be the broken pieces flopping around in there
  17. #42
    May 2008
    los angeles
    nah man.. all cylinders are firing.. just the right side of the motor (viewed from front) knocks.. but this weekend im gunna put a new motor in it..
    will a motor from an 88 work? mines an 87 and both engines are FI
    -Tom
  18. #43
    May 2008
    los angeles
    oh snap! that was you? so what do you say man? will i be able to get the digi speedo here in the states? is it the same connections as the analog ones? besides the speedo cable hookup
    -Tom
  19. #44
    May 2008
    los angeles
    bump...
    well guys... what do you say? will the a20a3 from an 88 work for my 87?
    -Tom
  20. #45
    May 2008
    los angeles
    BUMP...
    c'mon guys i need answers.. i have the a20a3 from an 88 model year accord.. will the intake manifold work with my stock 87 ecu???
    -Tom
  21. #46
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    just use your 87 intake manifold and you will be good to go. 88-89 have some different components, so just save yourself the headache and only swap the head/block from the new engine.
  22. #47
    May 2008
    los angeles
    yeah im just swapping the intake manifold.. i dont see any way of my black box accepting the secondaries on the 88's engine.. so far its going good guys.. intake manifolds off the new engine and im awaiting tomorrow after work to start the teardown on the new motor.. wish me luck
    -Tom
  23. #48
    May 2008
    los angeles
    i had an idea... what if i just keep the secondaries "dead" as in not functional.. just open all the time.. will it work??? cuz ive seen how much bigger the 88s mani is and i would like it for mine but im not too sure of it
    -Tom
  1. oil light flashing
    By import racer in forum EFI Tech
    Last Post: 03-07-2010, 04:46 PM
  2. oil light flashing
    By import racer in forum Carburetor Tech
    Last Post: 02-11-2010, 05:12 PM
  3. Flashing Oil Light
    By conozo in forum 3geez Accords
    Last Post: 06-12-2007, 03:01 PM
  4. Oil idiot light flashing
    By greekguy7 in forum 3geez Accords
    Last Post: 12-06-2004, 10:56 AM
  5. s3 light flashing on my dash cluster?
    By 89queludesi in forum 3geez Accords
    Last Post: 09-29-2003, 03:37 PM
