hi currently oil is leaking on my exhaust and im not sure if its from the hose or the oil pan it self any advice?
look at the oil filter base too.
not sure but check the hose that goes to the pcv box, it could be that
No, the oil filter screws onto the oil filter base attached to the engine via 3 10mm bolts, there is a gasket between the engine and this filter base unit nortorious for leaking oil onto the exhaust. The filter gasket
usually runs about $5 at honda and is simple to change.
Phil
