Results 1 to 8 of 8
Thread: FPR for carbs?
    SEi User Mantis88LX's Avatar
    97 Dodge Neon
    Athens AL
    FPR for carbs?
    can we get fuel pressure regulater for carbed accord? ??
    PhydeauX's Avatar
    Eastern Penna
    Yes, but its not going to do anything for you. The fuel pressure on a carb car just fills the bowl, as long as it fills the bowl then everything is fine. You up the pressure a little bit and it will keep on filling the bowl just as before. You up the pressure too much and the needle valve won't be able to stop the flow when the bolwl is full and your going to flood.
    andy
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Just don't get a Dail in FPR. they lock up and shut off fuel flow @ hige rpms.
    Spectre
    Purolator
    are common dial in fprs.
    I tried one... despite what anyones says. The stock keihin sees an improvement in throttle response... 3.5 - 4.0 psi
    @ 4.5 psi or higher it will just cause the dial in fpr to lock up quicker.
    in either case I saw a 3.0 - 12.0 psi fpr made by summit racing.
    it has the option of being a 2 port or a 3 port.
    10/Honda/Ridgeline
    NJ
    dude mike, u keep changing ur lil pic thingie and its hard make out where u are unless i see ur handle. man...... ur nuts.
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    Mike is one of the coolest guy I know on here!!!!!!!!!!!!
    A20A1's Avatar
    Sep 2001
    accord HB ( metallic green)
    B.C Chilliwack
    While were on the topic of adjustable fuel press regulators, can having one put more stress on the pump. Does the regulator just hold back the fuel till it reaches a desired pressure then lets it thru ( correct me if i'm wrong ). If so would that not stress the pump more ? thanx for any info
    89 efi conversion
    17" katana, lude arms, full 2" exhaust/hollowed cat, Ractive intake, centerforce dual friction, msd coil/wires
    A20A1's Avatar
    Sep 2001
    it would stress the pump if the pump puts out excess pressure... like a 10 psi pump with a 3.5 psi regulated pressure... you would need to have a fuel return line to the fuel tank to bleed off the excess.
    I'm not sure if the stock pump even reaches 3.5psi
  1. um help with carbs
    By Noodle in forum Carburetor Tech
    Last Post: 01-08-2006, 02:54 PM
  2. Are all carbs the same?
    By fuzzy audio in forum Carburetor Tech
    Last Post: 09-16-2003, 08:15 PM
  3. Crazy Carbs
    By FrankD in forum 3geez Accords
    Last Post: 09-12-2003, 08:08 PM
  4. LXi manifold for 2x carbs? (pic)
    By POS carb in forum Carburetor Tech
    Last Post: 10-07-2002, 10:20 AM
  5. 2 carbs!
    By smallballn in forum Performance
    Last Post: 08-13-2002, 02:35 PM
