I basically get about 15 feet out of my driveway/anywhere and the car loses power. Only does this when the car is at normal operating temperature. Basically bogs then dies. I suspect either fuel or electrical. I first thought there was an obstruction in the lines(filters), so i replaced several of the rubber hoses and changed the fuel filters. Worked fine for a couple days then the same thing happened. I dont think it is the filters, but just an random problem caused by something else. It seems to only happen after i turn the car off wait a certain amount of time then turn the car on and drive.
Other times(like in the morning) it works fine. I drove to class today and back. It sat for 30-45 minutes, went to start it again and that is when i made it about 15-30 feet before it just lost all power and died. Would not start. I left it for about 2 hours came back and after cranking it for a second it started. Drove it home after that with no problems.
I have also considered it might be the fuel pump going out, but i replaced it only about 2-3 years ago. When it does run, it has plenty of power even in the 3000-4000RPM range with speeds 60-70MPH.
Since it is a carb, vapor lock? Can anyone shed some light on where i should be looking?
88 LX
Thanks
