Ok I needed a work car, in the past 10 years I've owned over 30 cars and not a single import. But when time came to get a car to run back and forth to work even my Camaro buddies recommended a Honda. Seems they feel they are reliable and run forever. So I picked up a good deal on an '87 Accord from a hole in the wall dealer. I was amazed that even after drving the car three seperate times over two weeks it was one of the smoothest running cars in that price range I had ever seen plus the interior was immaculate and the A/c blew cold as ice. Well thinking I had the work car thing licked I bought it. well the second day it left me sit 100 miles way from home. Bad fuel pump. the filler neck is rusted big time so I assume alot of rust got into the tank. Replaced the fuel pump & filters and it ran good for another few days then quit. Got it towed AGAIN and this time tore off the tank and replaced all the fuel filters again and cleaned the massive amount of rust from the tank. Well the car now will run good for a day then not run. The problem was today the car would not idle, at ALL. It does this alot...sometimes its a broken vacuum line sometimes I have no idea what's wrong. I assume this car has major carb woes...........a replacement carb is $400 and I'll take the car to a junkyard before I spend $400 on a carb (paid only $900 for the car as it). My question to any guru's here is this carb has the most emissions garbage on it i've ever seen.....I live in an area without emissions so what can i tear off of the carb and still have it run?? This stuff has gotta go. The reliability of this Honda is pitiful, it has left me sit more times than the 30 cars I had before it COMBINED. So much for Honda quality I guess. So is there anything I can do here?? Selling the car is impossible since I don't even have the title yet. Is there anyway I can salvage this carurator to make the car actually run?? Rebuild it?? If I tear it off none of this emissions garbage is going back on that's for sure.................also will a dealer laugh at me if I bring a 15 year old car in for the filler neck recall?? I assume they will laugh me out of the place. Otr should I just junk this car and take the $900 loss?? Its would be a shame since the motor itsself uses no oil and runs ok-when it runs
