Results 1 to 13 of 13
Thread: valve cover gasket (inc. sealer)?...
    Jun 2008
    NY
    hey guys,
    Just picked up a felpro valve cover gasket, the people at the autoparts store said I must also use permatex blue RTV silicon gasket maker to seal the gasket.
    I was under the impression that I was to simply add in the gasket, and screw the cover back on, no extra sealents needed. Should I use the sealent anyway?...
    Thanks!
    1989 Accord LX-I - Brembo f.Rotors, Hawk HP+ pads, ATE fluid
    1996 Mustang Cobra #404 - somewhat stock
    Re: valve cover gasket (inc. sealer)?...
    You want to use a sealer at the sharp corners that seat next to the camshaft. Just a little dab will be sufficient. You don't really need it, but the possibilities for leaks are greatest at those points.
    I've always used black RTV sealer and haven't had a problem, but some guys here recommend against RTV with rubber gaskets.
    Idaho
    I agree ^^
    Jun 2008
    NY
    ok! Thanks for the input guys...
    I would not use rtv on the valve cover gasket except for those corners around the cam gear end. Just a touch on the two spots. You need to keep in mind you want to be able to remove the valve cover in the future without tearing up the gasket. The rubber gasket should stay intact on the cover when you remove the cover to adjust valves and check head bolt torque during routine servicing.
    If you need something to hole the gasket in place you can use weather strip glue (gorilla snot) or either permatex hi tack. Either would be used sparingly between the gasket and cover. For the most part the gaskets and cover are designed for a "locked in fit"
    i used the grey colored gasket sealer
    SEi User turabaka's Avatar
    Aug 2007
    Boise, ID
    I put in a new one I bought from Napa when I switched over to the lx-i valve cover. I didn't use any extra sealants aside from just the gasket. No leaks at all so far.
    Jun 2008
    NY
    I had to actually use a thin line of sealer around the entire 'inset' of the valve cover to just get the gasket to stay in place with the cover...
    Seems like the former owner used sealer though, all the leaking areas had sizeable mounds of old dryed sealer, which was the cause of all the leaks.
    Good news though, the timing belt is a fresh-looking Gates one, so seems like I can hold off on doing that for a few more months at least!
    Jun 2008
    NY
    Lost a valve cover bolt... and of course only Honda sells them (hopefully), now the waiting game begins...
    LXi User 87lxiaccord's Avatar
    1987 honda accord
    st.pete
    go to the junkyard and pull a couple or got to the hardware store and get a nut that is the same size and thread pitch
    <3 sohc
    Jun 2008
    NY
    ...update, found it thankfully! I do have to go lookup some junkyards in the area though for future use.
    Quote Originally Posted by paul View Post
    You probably already know this, but you want to be in the habit of removing any old sealer before adding more.
    Junkyard = Disneyland
    Woohoo!
    Jun 2008
    NY
    Woohoo!
    I've owned a dohc saturn, I know all about scraping off gasket sealer
  1. Valve Cover Gasket
    By bushbean in forum 3geez Accords
    Last Post: 07-23-2007, 12:09 PM
  2. Oil Pan & Valve Cover gasket question..
    By 88Accord-DX in forum 3geez Accords
    Last Post: 05-26-2006, 10:47 PM
  3. valve cover gasket...
    By gsus in forum Classic Honda Community Chat
    Last Post: 01-24-2005, 01:03 PM
  4. valve cover gasket
    By 89accord_lxi_coupe in forum 3geez Accords
    Last Post: 09-04-2003, 09:14 AM
  5. valve cover gasket
    By 2old_honda in forum 3geez Accords
    Last Post: 03-24-2003, 08:49 PM
