I dont know about u all, but every once in a while an air bubble must get stuck near the bleed screw, and if i'm sitting in traffic or at a light for a while the car will get a little warmer than it should before the fans kick on (2/3 to 3/4).
My solution (coincidentally) since my ac compressor burned up long ago, was to remove (with tin-snips) the ac belt, so whenever the car gets too warm, I hit the ac button and turn the fan on low, which kicks on the cooling fans anyway.
NOW the fans wont come on at all when I turn on the ac switch + fan!!!
I know nothing about the ac except to leave it alone, can someone give me an idea of what to start checking please?
before I get flamed, I will say I replaced the water pump last may (gmb) and checked it again and replaced thermostat (160) when I put in the jdm motor just this past January. ALL the coolant hoses have been replaced (including those little fuckers all over the intake), ALL clamps (except on plastic receptors) have been switched over to screw down style, and there are NO LEAKS. I looked. ALOT, when it was hot and cold and I cant find any coolant anywhere. Don't know what else to do.
thanks
happy solstice
