Results 1 to 13 of 13
Thread: 89 accord idles to high
    Jun 2008
    hi, i am new to this forum as i just recently bought a 89 accord (i am only 15)
    well it starts fine then it seems to idle at about 1,500rpm then gradely moves to 2,000rpm
    and idles there, the car is a project car and i really need to figure this out before i start on other things and also u can hear it sucking in air when its idling
    after u rev the car and it goes back to idle it makes a weird noise coming from around the plenum <<< not to sure on spelling
    any help would be appreciated thanks
    Re: 89 accord idles to high
    Is it a carb? If so, is the car warmed up? These carbs idle high until the engine is up to operating temps.
    Jun 2008
    nah its a 2.0si sorry for not posting in the first thred
    I would check for vacuum leaks.
    Jun 2008
    could u help me out with like a diagram of all the vaccume hoses on a efi i can only find ones for carbs, and could u give me a expample on how to check for these leaks
    check out the 3geez wiki there should be a link for shop manuals on there
    nm here they are
    http://3geez.wiki-tv.com/Honda_service_manuals
    You can use carb cleaner. Spray it on the lines and the engine will act differently if you sprayed the cleaner on a leak.
    Jun 2008
    nm here they are
    couldent find them on there but im haveing a second look, any idea were they would be under ?
    Quote Originally Posted by strange View Post
    get the 86-89 master manual look under
    fual and emmsions
    should be like 12-7
    Jun 2008
    yeh i found them thanks mate, umm i think the car is missing the air cleaner, and the vacume hose from the idle controll solanoid valve has a bolt in it, could this be the problem ?
    Jun 2008
    bump
    Probably. It's a cheap enough first step.
    Jun 2008
    ok i found the problem, was the fast idle valve being dirty as hell
  1. 87 accord idles funny
    By lkjohnson in forum 1geez Accords
    Last Post: 08-17-2010, 07:30 PM
  2. my car idles high (at like 2k-3k)
    By fijisac in forum Carburetor Tech
    Last Post: 04-22-2009, 07:58 PM
  3. Carb idles 2 high after vacuum removal
    By MiKeLx in forum 3geez Accords
    Last Post: 12-10-2004, 07:07 PM
  4. Idles high...how to adjust?
    By whyterice in forum 3geez Accords
    Last Post: 04-03-2004, 05:37 AM
  5. engine idles high
    By Aarie$$oul in forum 3geez Accords
    Last Post: 07-29-2003, 02:53 PM
