cygnus x-1
RPM is the most interesting. One of the gauges on the Megasquirt gauge panel (when plugged into a computer) is injector pulsewidth. This gives you pretty much a direct indication of how much fuel is going into the engine. It's interesting to watch it as you're driving. You would think that higher RPMs would mean a longer pulsewidth and more fuel, but it's not always so. One of these days I should try cruising at the same speed in different gears and see what the PW does.
Well, the pulsewidth will vary to match the engine's manifold press and VE at that rpm, but I guess if you can calculate the total fuel going into the motor vs your speed/distance..
The hp required vs bsfc is a pretty complex thing. I'd say for most large engines, they most efficiently generate the power required for cruising at a very low rpm. Like 1500rpm on the open road. But it's a little different for a smaller motor, while it might be able to generate the power required at that rpm, it would actually use more fuel to do so than it would at say, 3000rpm. You're talking about pulsewidth, but that's only half of it, the other half is how much energy the engine is able to generate from that pulsewidth. That's what a brake specific fuel consumption graph is, basically curves of different amounts of fuel burned at different rpms to generate certain amounts of power. I think you hit the nail on the head in principle about cruising in different gears to experiment, but I suspect that in reality, the rpm difference between the gears is too much. I think a change in final drive ratio would be a better experiment.
I really wonder about the gearing the oems put in some cars. Mpg is more and more important these days, but doesn't even the new rsx cruise at around 4k rpm? I highly doubt that is anywhere near the optimal point in that motor's bsfc curve for generating the power required at that speed. And that's a 6 speed too, wtf, why isn't the last gear a little higher? I guess they don't want you to have to downshift to go up hills..
And I'm not even going to get into the s2000, wtf. I've heard the new corvettes get better mpg, at least on the highway, and I believe it.
Obviously the best way to do this would be to use an infinitely variable transmission, so you'd always be able to keep the motor in it's most efficient rpm/manifold press for whatever hp requirement encountered, but unfortunately, it's not like you can just swap one of those in..
I suppose theoretically you could get slightly better mileage with higher octane fuel if the ECU adjusts timing advance for knock. But it seems extremely unlikely that it would make enough of a difference to offset the increased cost of higher octane fuel.
The knock retard only lasts a few seconds, and the motor would only knock under high load, if at all, so I don't see how this would affect fuel economy..
I'm also pretty sure there is no ecu programmed to add fuel as a function of feedback from the knock sensor..
C|
