Results 1 to 10 of 10
Thread: Stop wheel wells from rusting
    Jun 2008
    My wheel wells are currently rusting out. If I sand them down and then put on some rust preventing primer followed by a rubber undercoat, will that slow the rusting?
    Ichiban's Avatar
    North of You.
    Re: Stop wheel wells from rusting
    Well, the best way is to sand all the metal back around the rust, cut out the rust, and mig weld in new material. Since you're probably not going to do this, your best bet is to try to neutralize the rust and keep the water out. Make sure you chisel the seam sealer off of the backsides of the rusted area, as it's often loose and trapping water underneath. Scrape it off until it is firmly adhered and reveals no more rust underneath. Grind off the flakey rust, then treat with a rust converter. I usually use Permatex rust converter. Sandblast first if you can. Then fill surface roughness and small pinholes with a quality fiberglass body filler, which will be water resistant and contain its own corrosion inhibitors. Make sure you replace the seam sealer with a quality product (I use Pro-form PF 206, comes in a caulking tube ). Also be sure you get all the angles, wheel well rust can involve visible body metal, the actual wheelhouse, and the trunk and interior. Anything not painted metal should be generously smeared with seam sealer first. Afterwards, prime and paint. Anything that isn't finished body metal, definitely cover with rubberized undercoat.
    ICHIBAN!
    "Now, even more better!"
    you can also buy a pint of epoxy primer mix it like you are going to spray then use a brush,it won't look the best,but it will stop the corrosion and you can paint over it.
    Quote Originally Posted by guyhatesmycar View Post
    trust this guy! he did a great job fixing his 2nd gens body he knows what hes talking about!
    AZ
    move.
    dead white and blue
    SEi User gp02a0083's Avatar
    1989 Lx-i Hatchback
    Jackson, NJ
    if your looking into stopping rust POR-15 is the way to go
    2.0Si User cubert's Avatar
    Feb 2003
    2012 Civic si, old bikes.
    NH
    Ive heard excellent things about the POR stuff...id say give that a try.
    look at the rust stopper eastwood.com has,it was pitted against the por and did much better.
    Jul 2008
    1989 LX Coupe 5 speed
    Rothesay
    I have used POR many times and in my judgement it does the job good.
    Vanilla Sky's Avatar
    1999 Penalty Box
    AFTER you have the rust fixed, spray the inner fenders inside the trunk with bedliner or a POR-type product. I've watched one of my parts cars go from rust free to rusted through, and it started inside the trunk.
  1. My DC's are RUSTING!!!!!!!
    By Sabz5150 in forum Classic Honda Community Chat
    Last Post: 01-11-2005, 07:28 AM
  2. WTB: inner wheel wells
    By killerb09 in forum Trading Post
    Last Post: 07-09-2003, 03:14 PM
  3. Plastic Inner wheel wells
    By 88LXi68 in forum Interior & Exterior Care
    Last Post: 11-04-2002, 08:13 AM
  4. Stock LXi Rims rusting
    By Dman87LX in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-04-2002, 01:01 PM
  5. help!! wheel shaking when i come to a stop
    By ryan86accordlxi in forum Performance
    Last Post: 05-30-2002, 08:23 AM
