hey guys i finally found a parts car for 200.00.it needs a window replaced,someone tried to steal cd deck.and ther is something wrong with ps system.not a bad deal,the problem is it's automatic.how much work would it be to make it standard 5-speed.
fairly easy to do, When I did my swap it took only a few days.
only pain was getting the pedal assembly's swapped out. It's a tight fit under the dash
would it be easier to take out the dash for the swap that might give more space, idk?
your not f-ing kidding bout those pedals! and getting the clutch cable hooked up was fun too. putting in the shifter is also a worthwhile experience.
do you need to chnge flywheel or not,i heard some people say you don't need to change the flywheel just remove something on it.
oh forgot to mention it only has 100,000 km on it.
