ok here the deal..my secondary vacuum diaphragm doesn’t want to open the secondary at all...ive checked for vacuum hose leaks but didnt find any leaks..but i did notice that the primary venturi is kinds loose. could that cause the secondary diaphragm not to open and ingage the secondary...if i manually pull the lever on the diaphragm, the flap will open and gas will start to spray only if i do it manually...so my questions are, is the primary being loose causing this problem..or could it be the diaphragm itself causing the secondary not to open..
Also is there a way to rig the secondary to open manually without the need of the vacuum? Thanks any help would be appericated cause my car is just to damn slow with out it working. By the way the car is an 89 accord 5spd..tune up every 3 thousand miles new fuel pump new fuel filters done in the last 6 months ..ngk spark plugs bosch wires…gets good gas miles probably cause of all the gas I save without the seconday.
