Results 1 to 11 of 11
Thread: cast iron weld
    1986 honda accord lxi
    Durham
    cast iron weld
    i herd a few things of what could happen if you weld on cast iron 1. it wouldnt have a strong hold to metal... 2. it wont stick. is it possible for metal to be welded to cast iron with a wire welding machine?
    SEi User
    south dakota
    Re: cast iron weld
    Yeah, but it welds like shit. I've done it before a few times when I've had to, basically the iron vaporizes away, and if you increase the wirespeed/filler enough to fill it in, the iron likes to crack and pull away from the weld..and if it doesn't, it still doesn't have shit for strength, and will break easily. You're dealing with 2 different alloys/metals, basically the iron lacks other metals present in the steel, behaves considerably differently, and I don't know how you're going to find or use an alloy that has the same properties as the iron. That might very well exist, but I don't really know what it is.. (or care) I would prefer an alternative to welding the material, like replacing the part entirely or doing whatever else it took to get the problem solved..
    cygnus x-1's Avatar
    Chicago area
    Re: cast iron weld
    I've never done it but supposedly you can weld cast iron with a stick welder using nickel type rods. A wire welder will likely be pretty hopeless.
    C|
    carotman's Avatar
    Montreal South Shore
    Re: cast iron weld
    Read this:
    http://www.mig-welding.co.uk/cast-iron.htm
    This is THE website you need to read.
    I need these parts!
    Ichiban's Avatar
    North of You.
    Re: cast iron weld
    We weld and machine cast all the time. Unfortunately, it fucking sucks. We've tried Arctec 50% alloy cast rod, Weldco 75% high nickel cast rod, and plain E7018 5/32. It actually seems like the 7018 rod machines off the best, but all of the rods have the common problem of the weld becoming extremely hard at the boundary between the original cast and the filler material. For simply joining the material, I'd say 7018 is sufficient, but we've yet to find a rod that really satisfactorily creates a machinable buildup. For example, I'd sooner drill oversize, tap and helicoil a stripped hole before attempting to build up, drill and tap in cast. Even if the drill lived, the tap surely wouldn't.
    Also remember, proper pre and post heating is critical with cast welding. Count on preheating the part to at least 100 Celsius and insulating and post heating for another 2+ hours. At worst, failure to do this will shatter the casting, at best the weld will be glass hard.
    Don't weld cast with MIG.
    No!
    Put the fucking MIG gun down.
    Anyway, hope my experience helps somewhat.
    ICHIBAN!
    "Now, even more better!"
    Re: cast iron weld
    Quote Originally Posted by guyhatesmycar View Post
    No!
    there is supposed to be some kind of new rod that works with a tig,but you still have to preheat, cast iron is a bitch to work with.
    Re: cast iron weld
    is welco still around? i have the old product guide,it lists what to use and how to weld specific items i'll look for you.i also have the antique audell welders quide there may be a forgotten old school trick to use, there are tips in there that guys i know who have been welding 30 years never knew.
    Ichiban's Avatar
    North of You.
    Re: cast iron weld
    Wel(d?)co has an outlet down the road from our shop. They do all our bottles and consumables.
    I just read the article on welding cast with stainless, and called my foreman and told him about it. We're going to try stainless MIG with low chromium, high nickel wire sometime soon here.
    ICHIBAN!
    LXi User Bass Man's Avatar
    Jun 2008
    Rogue River, So. oregon
    Re: cast iron weld
    I thought you had to AirArc it in order to weld it. Maybe that was just how they cut the old crap off.
    Durham
    Re: cast iron weld
    YOU CAN WEILD CAST IRON GOT PICS TO PROVE IT!!! checkout my updates in before and after turbo in a minute
    Ichiban's Avatar
    North of You.
    Re: cast iron weld
    Quote Originally Posted by custom View Post
    No shit. But can you weld cast iron and have it still machinable after? On an 11" diameter bore, we had to weld up about an inch of damage, and machine and blend it into the original material. Using a 4.5" boring bar with a lefthand 1" CNMG insert holder, and running at 33 RPM and .010"/rev, the cast rod weld material deflected that 4.5" bar over .100". It just about instantly destroyed the corner on the CNMG.
    Not what I call machinable.
    ICHIBAN!
  1. Die Cast Toy Models of 3g Accords?
    By PandA in forum Classic Honda Community Chat
    Last Post: 01-29-2014, 04:57 PM
  2. Accord Die-Cast models-all gens!!!!!!
    By gfrg88 in forum Classic Honda Community Chat
    Last Post: 01-03-2011, 10:47 AM
  3. iron or aluminum
    By lostforawhile in forum 3geez Accords
    Last Post: 07-05-2005, 11:45 AM
  4. z3 fenders | carbon fiber hood. cast your vote now!
    By CreativeAutoDesigns in forum Interior & Exterior Care
    Last Post: 09-11-2004, 06:20 PM
  5. iron pipe=big water problem
    By minus1 in forum 3geez Accords
    Last Post: 08-12-2002, 05:52 PM
