has anyone used one on there 3g? It says it works with cars that have MAP sensors, but i just wanted to see if anyone had used one.
i'd say it'll will work
is just a matter of the time to wire it in
i personally dont like "piggy back" controllers
they just alter the signals to the ecu to roughly do what you want
far prefer stand alone programmible ecu's
they do a far better job
it will definitely work, just understand what you are able to do with it.
all it does is modify the MAP sensor signal that the ECU sees. By manipulating the amount of load the ECU sees, you will add or remove fuel for given rpm and tps ranges.
from your user name I might guess you are trying to go turbo. if that is the case, you can use this to help control fuel, but you might also consider an MSD BTM to help with controlling spark a little bit.
yeah, I have a msd btm to go with it. does anyone have the color code and names of wires in the harness going to the ecu? My car is a 87 prelude, but I wouldn't figure there would be much difference between the lxi and my car
