Results 1 to 9 of 9
Thread: Blower problem
    LX User LxAcc510's Avatar
    May 2008
    1989 Honda Accord LX
    Where they say Hella, CA
    Blower problem
    My F**KN blower doesn't work properly...when i first start my car at the beginning of my day. turn my blower level from 0 to 4....NOTHING HAPPENS
    However when i get on the freeway and accelerate up to maybe 65m/h+...the blower kicks in.
    Anyone have an idea whats going on here?
    Aug 2007
    1987 Accord Carbed Auto Stock
    Re: Blower problem
    Could be bad brushes in the blower motor. When you get up to speed, it probably just bumps it around a bit until the brushes make contact. Try tapping the motor with a screw driver to see if it works next time you have a problem. I hope this helps.
    May 2008
    Re: Blower problem
    Quote Originally Posted by Pnem3 View Post
    Ok but before i try to tap the motor do you know where the blower motor is located? er can you give me an idea of where its located?
    nfs480's Avatar
    1989 Honda Accord SE-i
    Rogers, MN, USA
    Re: Blower problem
    It's right below the dashboard under the glove compartment. It's that plastic container-like thing on the very right.
    May 2008
    Re: Blower problem
    Quote Originally Posted by nfs480 View Post
    Yea i found that motor now. Cuz today i heard some light tapping and i followed the sound. Now what should i do with it to get my blowers to work properly?
    nfs480's Avatar
    Rogers, MN, USA
    Re: Blower problem
    Try replacing the blower motor resistor. I just ordered one for mine because it occasionally doesn't work when set to speed 3. It's possible yours doesn't work at all. If that doesn't work you might have to replace the motor. The nice thing about replacing the resistor is that it's cheap and you don't have to remove the motor from under the dash to replace it.
    May 2008
    Re: Blower problem
    Yea im planning on going to the junkyard and finding another blower motor. But in the mean time it usually starts working when i just tap it a few times
    SEi User Demon1024's Avatar
    Apr 2007
    NW Arkansas
    Re: Blower problem
    mine stopped working today too so this is perfect timing. THANK YOU!
    AZmike's Avatar
    Tucson, Arizona
    Re: Blower problem
    You may want to remove the blower motor resistors and inspect them before ordering any parts. It's just one wire connector and two screws under the glove box.
    I found that my resistors had some debris stuck to them so I was getting inconsistent fan performance at different settings. Cleaning the resistor coils and bending them apart a little solved my problem.
    Mike
  1. Problem with Blower when cold
    By nfs480 in forum 3geez Accords
    Last Post: 02-04-2009, 05:57 PM
  2. A/C Blower Not Cutting It!
    By Boltgunner in forum 2geez Accords
    Last Post: 07-25-2007, 06:57 PM
  3. Blower Motor Problem
    By azazel_18_2 in forum 3geez Accords
    Last Post: 07-12-2007, 06:53 AM
  4. A/C Blower Help
    Last Post: 07-12-2006, 05:38 AM
  5. Blower No Blow
    By skull1441 in forum 3geez Accords
    Last Post: 08-21-2004, 06:27 AM
